Old 06-27-2012, 09:51 AM   #1
truegearhead's Avatar
Door speaker install problem
I bought some new door speakers(I made sure to get shallow ones) but I think there still close to the back wall. The speakers are almost completely muffleled. I guess I need to make some modifications to the ported box that's in the door. Has anyone run into this?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 06-27-2012, 11:10 AM   #2
Ditch the "tuned ports" all together and just make a baffle mounts yourself from mdf. Then you can size up to a more adaquate 6.75" or 6x9" speakers or ??? to get some ok bass. 5.25" drivers w/o a boat load of power will still sound like garbage. Check out the boxster wiki or do a search here for a complete guide on overhauling the Boxster's sound system including a template for the baffles.
Good luck
Old 06-27-2012, 11:56 AM   #3
It's not the port. The speakers sent producing any sound. I cut the box in half just to be sure and no difference. They're moving, but they're not producing sound. Odd
2003 911 C2
Old 06-27-2012, 12:32 PM   #4
2003S's Avatar
If you're using the stock HU / amp, I believe it has a low frequency crossover that filters out the mid & high range signals to those "speakers", since they are designed to just be "sub wooferish".
I wouldn't think just swapping the speakers is enough, if you want to use full range speakers, I would think the amp / HU needs to be swapped as well?
2003 Midnight Blue S
LN IMS Retrofit
Old 06-27-2012, 12:39 PM   #5
Why wouldn't these just act like subs then?
2003 911 C2
Old 06-27-2012, 01:50 PM   #6
5.25" drivers won't go low... at least not w/o a lot more power... a lot more than the stock amps' 40W provide. And the door drivers are just "low" tone anyhow as a crossover is built into amp...
Suspect the range on your new 5.25" drivers isn't very deep and thus why they barely move and produce little sound... just like the OEM ones . Also, make sure fade on h/u is set to middle as amp's signal to door drivers is by combining front & rear channels from h/u regardless if you have rear speakers as not.
A countless number of us have gone down this slope before you. Search for "upgrading the Boxsters sound system" thread here or on Boxster wiki for details. It will be very helpful read and save you any more aggravation.
Old 06-27-2012, 02:00 PM   #7
A countless number of us have gone down this slope before you. Search for "upgrading the Boxsters sound system" thread here or on Boxster wiki for details. It will be very helpful read and save you anymore aggravation.
I never thought it would be so complex dam. So the speaker I have simply won't work. It sounds like they're the wrong resistance.
2003 911 C2
