Old 06-19-2012, 06:57 PM   #1
fuel pump &/or fuel pump relay problem
My 911 C4 starts right up but then dies after heating up & running 15-20 minutes. Then it'll crank but won't start. After sitting/cooling for awhile it starts right up but then the same routine persists; it dies after the 15-20 minutes. When you turn the key to the on position you can hear a high pitched humming in the fuel pump for 5-10 seconds before you hear clicking. It's not the normal clicking noise you hear from a fuel pump either. So I'm guessing after it warms up the fuel pump quits working or there's a fuel pump relay that's stops working or both...?
I read some of the hot starting posts but I'm guessing those won't restart after they're hot vs. the car quitting while running & then won't restart...?
Any feedback is greatly appreciated!!!
Thank you,
Dean
denvergold is offline   Reply With Quote
