Another higher mileage Tip saved from the IMS demons
92K 2001 Tip Base
Note the metal filings in the oil and around the bearing race http://986forum.com/forums/uploads01...1339126644.jpg http://986forum.com/forums/uploads01...1339126663.jpg RMS seal leak, No other symptoms, nothing in the oil filter. saved, Mike |
So open her up and look inside. Post some pics if you can. Is there any play or roughness in the bearing?
are you sure its from the bearing,have you opened it up to have a look
Thats a stage 3 bearing failure.. This is what we see just before the bearing lets go.. If that car had the IMS Guardian installed the alert would have occurred soon after this much material was released into the oil.
Good job saving that one! |
| All times are GMT -8. The time now is 07:18 PM. |
