Old 05-17-2012, 01:04 AM   #1
Gregg
Oil leak
Hi all
I have a 2000 Boxster S Tiptronic which has developed a slight leak in the area circled in white on the photo. The picture is not of my actual engine - I found it online. Any ideas?
Gregg44 is offline   Reply With Quote
Old 05-17-2012, 01:59 AM   #2
Steve Tinker's Avatar
It looks like the camshaft chain tensioner - you should be able to just tension it up.
If not, a new oil seal gasket is required.
2001 MV Agusta F4.
Old 05-17-2012, 03:10 AM   #3
Gregg
Thanks Steve - I'll try that. Hopefully it just needs tightening!
Old 05-17-2012, 09:54 AM   #4
BYprodriver's Avatar
Probably needs a new O-ring. 59ft/lbs if you want to try tightening it 1st. 32mm socket.
Old 05-18-2012, 11:06 AM   #5
my own oil leak
Two days ago while replacing the transmission oil, I also noticed an oil leak...
However mine does not seem to be from the chain tensioner but from the chain housing itself.
I cleaned the area and tighten a bit (1/8 of turn) the three 8mm small screws that are on the area, hopefully this will stop the leak.
If the leak persists, does this mean that the entire chain tensioner housing has to be removed to replace the gasket..?
Old 05-18-2012, 02:41 PM   #6
Sort of, if I am seeing that correctly it's the head gasket that needs to be replaced requiring removal of the cylinder head.
