Old 05-13-2012, 01:27 AM   #1
Gutting the standard cats
Hi just picked up a charlie chan exhaust of ebay for £160.00 result.
ive got some headers too and was thinking of gutting the standard cats,as i cannot seem to find any cat bypass pipes, ive heard this will throw the cel light but ive also read that by fitting long lambda sensor bosses this will aluminate the problem.
Any thoughts on this and has anyone done it or iam i better just fitting the headers,exhaust and leaving the cats alone.
Ive a 1.7 turbo diesel van which i gutted the cat and it made a big improvement allowing the engine to rev more freely but thats on a turbo
regards steve
whitecliffs is offline   Reply With Quote
Old 05-13-2012, 04:43 AM   #2
Rennzenn
j.fro's Avatar
If you're going to gut the cats you'll need to reflash the computer to prevent the CEL. The long lambda sensor bosses won't do it. Doing all of this, you'll pick up top end power, but you'll lose some low end torque.
Old 05-14-2012, 12:13 AM   #3
thats what i thought dont really want to go down that route of remapping the ecu
done that before with motorbikes just an endless spend of cash.
will leave the cats alone and enjoy the sound.
Old 05-14-2012, 05:40 AM   #4
Theres nothing to lose and everything to gain in terms of power when you delete the cats in a boxster. The front Cats are too close to the engine, and the rear cats are at a funny angle.
Last friday, I installed ebay headers, gutted the cats at the mid section, and added a NHP exhaust. No loss of torque anywhere. Feels like I gained between 10-15 hp ( Im running a 911 3.4 engine )
Heres the trick with the rear cats. They're not easy to gut. They're made of foil, and its EXTREMELY difficult to remove all the material. It took me 3 hours per a side, and thats with all the tools in my shop ( Torch, air chisel, long needle nose pliers ).
And, in addition to that, the exhaust gases echo and make a strange sound in the empty cat, so I am going to remove them and install a pipe instead.
Oh, and if you dont flash the ECU to ROW specs, you'll get a CEL. Ive read that Subaru guys install spacers to their rear o2s with a cat delete, and that BMW guys install O2 simulators. So there are 3 options to avoid a CEL
Bigsmoothlee is offline   Reply With Quote
Old 05-14-2012, 08:47 AM   #5
iam in the UK so my car only has the two rear cats and ROW specs ECU exhaust and header will be here thursday so got a few days to think which route to take
Old 05-14-2012, 09:54 AM   #6
You installed those like 200 dollar ebay headers right? How did you like them? I was looking at them today. Hows the fitment and does it make the exhaust sound raspy?
Tim1137 is offline   Reply With Quote
Old 05-14-2012, 10:12 AM   #7
I installed the $139 ebay headers. I could not believe they fit so well. I was prepared to have to do some cutting, bending, and modifying to make it fit, but it fit right in place.
Here is what I did:
Loosened muffler
Loosened center pipes
Loosened the headers
Finger tighten header bolts
Tighten 3 bolt flange
Tighten headers
Tighten muffler clamps
The fit was very close, and I couldnt install the flange gasket without prying the header and center pipes away from each other without a pry bar.
I imagine that if you were to just bolt the headers on and tighten them in without loosening anything else up, you would have an issue with fitment. But be prepared to heat all the bolts up with a acetylene oxygen and torch...or nothing will come loose without breaking.
The sound is amazing, very raspy when you accelerate, quiet at cruising speed. A lot of this depends on the silencing properties of the muffler, I chose NHP because it was supposedly mild.
And by the way, Im sure with fabspeed you'll pick up a few more horsepower than you would with Ebay headers...but there is no way in hell im paying $1700 for short headers. If someone offered an intricate, equal length runner design like the Euro spec BMW M3, I'd understand...but come on, these are only 2-3' at most!
Old 05-14-2012, 10:20 AM   #8
i found a US ebay seller doing them for 99.00 bucks on saturday.
here is the item number 230653008020
comes with gaskets bargin
Old 05-14-2012, 10:36 AM   #9
Im thinking about installing a set of the ebay headers and keeping the OEM exhaust muffler and the secondary cats. Im just trying to get a little more sound out of the exhaust without spending all the money on a system.
what are my options for keeping the CEL off for the cat codes?
Old 05-14-2012, 10:50 AM   #10
Near me theres 1/4 miles ish tunnel once ive fitted the headers and exhaust will do a video at 6500rpm through it....lol
Old 05-15-2012, 06:18 AM   #11
ok removed my exhaust system this morning only 3 bolts snapped on the header but soon removed them with an extractor.
Porsche should be ashamed of them headers look like there off a tractor.
Didn't know this until this morning my car is only fitted with 2 lambda sensors at the front.
So if i gut the cat its not going to bring on the cel light...or is someone going to tell me it will?
Old 05-15-2012, 06:24 AM   #12
gutting the cats in the manifold will, gutting the rear cats will not.
Im scared to remove my manifolds i dont want to break a bolt in the engine
Old 05-15-2012, 12:10 PM   #13
my car only has the cats at the rear but as from tomorrow she will be catless
as for the bolts thats the risk but if you have the means to repair then you'll be ok
i heated mine up 1st but if i had heated up the ones that snapped a little more i reckon they would have come out
Old 05-15-2012, 07:12 AM   #14
Porscheectomy
You're on a RoW car. There will be no CEL on your car for catalytic converter reasons what so ever. You could run with no cats at all and not get a CEL. Only North American cars have cat health O2 sensors.
Old 05-15-2012, 12:11 PM   #15
cheers for that cat-less tomorrow
