Old 05-05-2012, 10:08 AM   #1
Cruise Control acting up
Hey all,
For a while now my cruise control has been acting strange. I don't know much about the system and was hoping one...or many of you would have an idea as to what the problem may be:
Sometimes it won't turn on, the green light doesn't come on and it will not "cruise". The bulb is good because it will turn on SOMETIMES, when the stalk switch is depressed. When it does work, and i approach a slower moving vehicle, depress the brake pedal, it turns off the whole cruise control system (even though the switch is still "on"). Also- when the cruise light on the dash is "off", it NEVER goes into cruise control. I am going to check the brake and clutch sensors right now, but i looked at them recently and all appeared to be working correctly.
ANY THOUGHTS? I appreciate the help in advance.
anti-bling is offline   Reply With Quote
Old 05-05-2012, 12:17 PM   #2
xtremecc's Avatar
geez, Im having a similar problem. I replaced my car's battery and after that, my cruise control stopped working. The light in the dash does not turn on or anything. somewhat frustrating
xtremecc is offline   Reply With Quote
Old 05-06-2012, 09:21 AM   #3
Yeah, i was working on something recently and had to unhook the battery for a while...after reattaching the terminals to the cables, i've also had lock problems...frustrating.
Old 05-06-2012, 03:37 PM   #4
Location: Seattle - It's not Hell, but you can see it from here!
try doing a capacitive discharge.
disconnect the battery and touch the leads together for a couple minutes.
reconnect the battery.
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
