Old 04-23-2012, 01:11 PM   #1
Idle pauses. After catbypass pipe install. Air Bag Light??
Hey. I just installed secondary bypass pipes with new gaskets and bolts yesterday.
When I rev to any rpm. Lets say 3000rpm. And I let go of the gas. It stays at 3000rpm for an additional second before goes back down to idle speed.
When revving passed 4000 rpm, I hear a whistling type of noise from the exhaust. Are they related?
Any idea what could be causing these?
Everything seems tight except where the bypass pipes meet the U pipe connecting it to the Muffler.
The bypass pipe is inserted into the U Pipe and it is a tight fit I cannot move with my hands, but the bolts for the clamps on the U pipe are not currently installed. So exhaust gases could potentially leak from there. That is my best guess for now.
Last thing, My air bag light randomly lit up for 3 seconds, then shut off, then back on, then off. This was about 1 hour after driving for the first time with bypass pipes. Don't know if it is related or what it could mean.
Thanks.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 04-23-2012, 02:26 PM   #2
Airbag light should not go on/off. Once it trips it should stay illuminated until [code read and] reset by Durametric, PSTII or PIWIS - as I understand how the systems work. Might it have been a CEL which is probable considering O2 sensors and cat bypass (which require a spacer correct?)?
The 3000 studder sounds like relearning of ECU. Should be fine w/ ~ 50 miles or so.
Whistling definitely points to a leak somewhere in system. A quick test, if you have some handy, is to put some exhaust heat wrap on the connection. Though it feels tight by hand, once under load the whole system flexes a fair amount and at 4000 you're getting into the power band.
Good luck
Old 04-23-2012, 09:50 PM   #3
No it is the air bag light. No CEL on.
I just read on 986faq.com that it is a common problem associated with the air bag sensor in the belt buckle and there is a Porsche technical bulletin for it.
As for the Exhaust. I have the 2.7 Boxster. There is no O2 sensor in the mid pipe and it does not cause CEL or emission testing problems.
I found the problem. I turned on the car and put my hand around the connections. Exhaust gases were leaking out of two places where I did not have the bolts installed. So I am buying bolts tmrw from Home Depot and tightening it. That should fix everything.
I drove about 60 miles this morning for the first time after installing them before the ECU re-learned as you say. And after I drove it again for 5 miles a few hours ago at night, the idle pause was suddenly gone and seems back to normal. For now.
00 2.7 5SPD MT
