Old 04-23-2008, 07:35 PM   #1
Sentinel's Avatar
HELP Parking Lights don't work
I installed an LED tail light on a 2000 Boxster. It's actually only LED on the brake light part and the stock bulbs for the rest.
The turn signal, reverse, and brake light all worked. Even the fog light on the driver side work - but not the parking light. Worse, even the front marker lights are out too. Did the usual check with the multimeter and the fuses. I even swapped the tail light assembly from driver to passenger side with the same result. Power flows to all the other bulbs but not the front marker and parking lights (bulb #2825) or the rear side marker (bulb #5007).
I also searched the forums here for any clues. Have I accidentally blown a relay? Or did I miss a fuse? Side markers fuses are supposed to be in A3 for the right and A4 for the left. I'm stumped.
Guest Driver
Sentinel is offline   Reply With Quote
