Old 03-20-2012, 02:30 PM   #1
gas cap lock
recently got a 2001 and noticed that when I lock the doors, the gas fill door doesn't lock. in looking at this a little closer I noticed the plunger that comes out to go into the receiver in the door falls a little short. is there a way to adjust the plunger?
thanks
irag is offline   Reply With Quote
Old 03-20-2012, 06:15 PM   #2
WV Boxster
wvboxst3r's Avatar
Read another post on it. Don't remember much but search it. Something about a bad servo or something.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 03-21-2012, 05:01 AM   #3
John99Boxster's Avatar
There is a small plastic loop that goes around the plunger. It may be restricting it from moving into place. you will have to look inside of the hole where the plunger comes out and pull that loop with a pair of needle nose pliers.
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
John99Boxster is offline   Reply With Quote
Old 03-22-2012, 12:24 PM   #4
thanks, I'll give it a try.
Old 03-22-2012, 03:48 PM   #5
Had this problem on mine, pushed it in and out a few times, now locks ok.
Le Samourai is offline   Reply With Quote
