Dead battery - no frunk access
This has to be one of the worst design decisions ever. 08 RS60 - Dead battery can't pop trunk. Easy enough to wire up to the fuse box, but that didn't do it either. Bought a Black-and-Decker lighter-to-lighter charger at 1050pm local Target, and it opened right up.
Seriously though - did some German decide to play a cruel joke on the world by putting a battery-powered trunk switch on a trunk that closes on the battery? For a company in 2008 that couldn't find a way to put an Aux input on the damn stereo, I'm shocked they went to the trouble to do an electronic hood switch!!!! Thankfully the car drives like a dream... |
Been discussed many times, but there is an emergency release cable accessible from the drivers side wheel well. A bit challenging to reach, I hear, but it should be there. Some have rerouted to the tow hook hole on the front bumper.
I then rigged up normal jumpers to the battery and am back on the road this morning! |
The emergency "rip cord" for the front trunk is located on the passenger side inside the headlight area. Remove headlight pod and you will see it . Just extend it and re-rout it to the tow "plug" area. The cable moves from center to passenger side, so... drop the cable thru and around (to use as a pulley) the plastic bracket (black) and go back towards the center of the car. This makes it a easy to pull.
the driver's side cable is the one from the door latch, that breaks !!! I have lubed mine and I am careful every time I use it so I do not "break it" as it is 12 years old. SO that is why I installed an emergency "rip cord" for the rear trunk as well as the front "bonnet" Good luck with your project !!!
It's in your owner's manual and discussed numerous times herein. Many have had batteries, including me, and dealt with it without moaning. Glad your jump worked.
| All times are GMT -8. The time now is 08:32 AM. |
