Radio Fuse - 2002 Boxter
I have just purchased my 2002 Boxter at auction. The radio is totally dead.
I have the maintenance book and radio code & presume the fuse needs replacing. My question is - Which of the fuses connects to the radio? Do you have other suggestions on what I might check to make the radio work? |
You should have a fuse diagram either in the manual or in the fuse box itself. It is a little fold out sheet tucked in there.
If not, the dealer can hook you up. If I am not mistaken, there is also a fuse in the back of the becker unit. You may have lost both fuses! You will also need the radio code once you get power back to the unit. If you don't have that, it is off to the dealer again. Good luck! :cheers: |
Here's a fuse chart:
| All times are GMT -8. The time now is 01:37 PM. |
