Old 01-04-2012, 05:52 AM   #1
WV Boxster
wvboxst3r's Avatar
rough idle with oil filler cap off
I have been reading about the AOS and the white smoke. My car is new to me and I have seen the puff.
So I just was out pulling radio and did the pressure test on cap. It was a little tight to start twisting but not much pressure. But the idle got rough and tried to smooth out, heard a vacuum like noise. Again very little suction but idle changed and heard air.
Is this normal.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 01-04-2012, 06:41 AM   #2
Yes, it should run rough with the cap off since there is now a vacuum leak in the intake system.
To check the AOS, put your hand over the opening to seal it. You should feel just the slightest amount of vacuum.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-04-2012, 06:46 AM   #3
If you run with the cap off long enough, it will throw a CEL, too.
Old 01-04-2012, 07:10 AM   #4
WV Boxster
wvboxst3r's Avatar
Ok, I did not hold hand on but will do that in next couple of days. But from feeling of cap there will be very little. I thought that was normal with idle. New to Porsche so just being over careful.
