Old 12-31-2011, 05:41 PM   #1
RHD short shifter?
Hi all,
Just installed a short shifter in my 97 986. Problem is, I'm in Australia and the stick points to the left hand side of the car (for us models)...
Can I just bend this to the right or can I unbolt it and turn it around? Is kinda silly with it angling off to the passenger!!!
Appreciate your advice.
Sam
Australian Carbon Fiber nut
sparker is offline   Reply With Quote
Old 12-31-2011, 05:42 PM   #2
Porscheectomy
It's supposed to stand straight and that's what it does when you flip it.
Old 12-31-2011, 06:52 PM   #3
How do you flip it? If I undo the two nuts, the shaft still is not able to be removed?
Sam
Old 12-31-2011, 07:10 PM   #4
Porscheectomy
Sam
The lever is held on with a bolt and nut in the anodized counter lever. Just take out the bolt and flip the lever.
http://986forum.com/forums/general-discussions/15307-newly-installed-short-shifter-knob.html
Old 12-31-2011, 08:43 PM   #5
This is one of Che's shifters, it has a nut on each side with a stud connecting them... Not sure how to remove the stud?
Sam
Old 12-31-2011, 09:03 PM   #6
Porscheectomy
Sam
It threads into one side. It unscrews. Just don't ruin the threads getting it out.
Old 01-01-2012, 06:15 AM   #7
I had to do exactly that, removed bolt on the right and pushed pin out, flipped over and replaced pin..
Fr3n2y is offline   Reply With Quote
Old 01-03-2012, 01:27 PM   #8
Can I confirm if it needs to be screwed out or pushed out?
Sam
Old 01-03-2012, 02:39 PM   #9
Porscheectomy
Mine was threaded.
Old 01-03-2012, 02:41 PM   #10
OK no worries, did you just use two nuts on one side to un-screw it?
Cheers,
Sam
Old 01-03-2012, 02:43 PM   #11
Porscheectomy
Cheers,
Sam
I think it came out with just one nut on it, but jamming nuts is the best way.
