Old 12-20-2011, 07:11 PM   #1
Code Read with Durametric
First of all I think this tool is great. Never user one so I'm very glad that I can now read the faults in the vehicle and diagnose issues. Haven't played around too much with it but here's what I did so far:
- checked the fault codes on all supported features of the car. Pretty comprehensive. Does show you options what you don't have. Parking assist for example which I don't have.
- Was able to manually command start and stop of various components, radiator fans, CEL light etc. Good to make sure things are working.
- Tried to test the Xenon lamp and issued a error that component was not present. True, I have OEM HID.
- Did not reset the codes to see if they are old or still valid. Wish it ave me a date stamp on the error.
It did fail me on the readiness which I believe is what you could use to determine if you will pas the DMV inspection. Mine fails miserably. Some other faults are due tomthings that PO did. Replaced stock seats with sport and disconnected harness, did some hot wiring to alarm to do something with the radio etc. But the O2 sensors bother me. I did see the one by cylinder 4-6 was dripping with engine oil. Cleaned it but might have to replace after I change the coil tubes.
Below is the work log from the program. More to come later.
Bosch Digital Motor Electronics Motronic 7.2
Module Identification
Part Number 986.618.660.03
Supplier Part Number 004157026450
Current Fault Codes
P1576:
Porsche fault code 274 - Cruise control readiness light via CAN exceeds limit value
P1119:
Porsche fault code 5 - Heating power O2S ahead of cat. c. bank 2
P1128:
Porsche fault code 360 - Oxygen sensing adaptation idle range bank 1
P0150:
Porsche fault code 18 - O2 sensor ahead of cat. conv. Cylinder (4-6)
P0442:
Porsche fault code 97 - Fuel tank ventilation minor leak below limit value
ABS/PSM 5.3
Part Number 996.618.135.01
Supplier Part Number 02730041780246
Current Fault Codes
No Faults Found
Airbag B05
Part Number 996.618.219.01
Supplier Part Number B05
Current Fault Codes
3:
Supply voltage
73:
Child seat detection
1:
Airbag warning light
Automatic Air Conditioning H01
Part Number 996.653.101.03
Supplier Part Number 36
Current Fault Codes
20:
Combi-interface fault
21:
Ambient temperature sensor fault (intake duct)
22:
Instrument panel temperature sensor fault
23:
Footwell blow-off sensor fault
26:
Mixing flap motor fault
27:
Central flap motor fault
28:
Footwell defr. flaps motor fault
29:
Outs./recirc. air fl. mot. fault
31:
Fresh air blower fault
33:
Sun sensor fault
Alarm I32
Part Number 996.618.260.07
Supplier Part Number 080504003007
Current Fault Codes
49:
K lead
Status: not present
Occurance Counter: 3
This fault is displayed for informational purposes, it is not an indication of a problem and no repair is needed.
11:
Voltage failure during alarm output
Status: not present
Occurance Counter: 1
10:
Voltage failure at terminal 30 with alarm system active
Status: not present
Occurance Counter: 2
33:
Interior sensor faulty
Status: not present
60:
Central locking limit position Lock not reached
Status: not present
Occurance Counter: 9
Current Fault Codes
P1576:
P1119:
P1128:
P0150:
P0442:
ABS/PSM 5.3
Current Fault Codes
No Faults Found
ABS/PSM 5.3
Current Fault Codes
No Faults Found
Old 12-20-2011, 09:39 PM   #2
1999 base
Meir's Avatar
You did not preform the most important test
Under DME, check for camshaft deviation.
The reading will show you a value between 0 and -8.
The most important thing is to see that the value stay steady on idle. The graph will show a strait line.
That will confirm that the IMS is in a good shape. If the line go up and down, well... you have a problem.
Good luck
Old 12-21-2011, 05:49 AM   #3
Good luck
Would I do this while the car is idling or do I have to drive it around?
Old 12-21-2011, 07:17 AM   #4
1999 base
Meir's Avatar
No need to drive it Bala.
Just let it idle and make sure the line stay steady.
This is what our dear friend JFP in PA posted as reply to my question in the same matter.
Camshaft position deviation. - Pelican Parts Technical BBS
I’m also a new owner, and I’m trying to learn as much as I can from the more experience ones.
It is great to have people like JFP and many others that are willing to take their time and share with us their knowledge.
Good luck and enjoy you boxster, I know I do.
Old 12-22-2011, 06:59 PM   #5
After a full day of wrestling with the new top, wanted to have some fun and got back on the code reader. Here are some screen shots. Does it look like my IMS is feeling good at the moment. Can I sleep peacefully for a few days?
Camshaft 1
Camshaft 2
Camshaft angle
And then I have these errors. Need to get my DMV inspection done. I have the Borla performance exhaust with the stock headers. PO said they would pass. Given these fault codes am I looking at a fail?
Old 12-22-2011, 09:50 PM   #6
tonycarreon's Avatar
can't speak for NY / long island, but a "fail" component is a failure on Maryland Emissions requiring it to be resolved and retested.
we have a two-step inspection where the state performs the OBD / emissions inspection every two years and a third party does the safety inspection when you first register the car.
Old 12-22-2011, 09:53 PM   #7
nieuwhzn's Avatar
"Can I sleep peacefully for a few days?"
Nope, you start driving your car! Looks like you're spending all your time wrenching. Today was a beautiful day on Long Island. I even had the top down. Ho, ho, ho......
nieuwhzn is offline   Reply With Quote
Old 12-23-2011, 06:34 AM   #8
For the emissions: if you have cleared any codes, it will fail untl you drive it for a bit. It also had to be warmed up to operating temp.
garrettoomey is offline   Reply With Quote
Old 12-23-2011, 07:06 AM   #9
1999 base
Meir's Avatar
as for your IMSB
looks solid as a rock.
Old 12-23-2011, 07:10 AM   #10
Camshaft deviation looks good but the value of cam 2, 6.3 is out of spec, should be +- 4. Check it again after the car is fully warmed, meaning after being driven for more than 1/2 hour and the radiators have cycled a couple of times. Cam 2 on mine varies between 5.3 and 6.X depending on temp. I'm not too worried about it being slightly out of spec as the car runs fine.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-28-2011, 05:16 PM   #11
Found the cause for the "Cruise Control readiness light exceeds limit value" error code. The bulb for the CC light in the dash was missing. Taking from another and putting it in not only lit up the light but also cleared the fault.
There are some others that are empty. Is that the how it's supposed to be. I don;t have some options like PSM but about 6-7 are empty. Wondering what I'm missing out on!
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 12-28-2011, 10:17 PM   #12
Autobahn Glanz
WhipE350's Avatar
Mine had some empty slots too. My car only has something called the Sport Package, pretty base car. I got a bunch of black/tan bulbs and filled them up to see if I was missing anything too. I had just got the car and was learning a the time. The odometer light was out and the previous owner gave me a discount for that. I think I took back out the ones that didn't light up when the key is first turned. I'll be getting the Durametric at some point too, based on what I read it sounds like I might get codes for each bold I took out and put back in.
Old 12-29-2011, 04:18 AM   #13
Even though i have some empty slots the only code i got related to the dash instruments was the CC light. Mine is an S and the window sticker says 'Sport package'. I tried to get a picture of the dash with the descriptions of the lights from a manual but, unfortunately i dont have one and the only ones i can find online is not matching my car layout. Ordered one from Sunset.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 05-14-2021, 04:59 AM   #14
PaulDash's Avatar
Digging up an old thread... this is the only place on the board I've found a mention of the code that I'm seeing on my car:
Current Fault Codes
22: Instrument panel temperature sensor fault
The dashboard was out and lots of things disconnected. What am I looking for when trying to diagnose and fix this?
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
Old 05-14-2021, 05:23 AM   #15
What's the code you are seeing Paul? Might want to do a full scan and post all the codes.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
