Old 11-27-2011, 06:10 PM   #1
Question - 996 GT3 6 Piston 350mm Calipers
In sum, may I clear the above mentioned calipers on MY03 'S?
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
Old 11-27-2011, 06:59 PM   #2
Crazy Austrian
harryrcb's Avatar
18" or larger wheels are not problem but the mount holes are different. you will need the gt3 hubs or find a way to modify yours
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 11-28-2011, 10:49 AM   #3
Very well. Thank you kindly!
OH yeaaaaaaaa BUT the question is why do you need more breaks. a Stock boxster S with padget or some other competition pad will stop just fine, in my case I went to a larger power plant which facilitated the need for larger brakes. I did fine with my moded 3.2 motor and stock brakes. So is it worth the money ? In my opinion stay stock unless you stick a larger carrera engine in your car.
That is the end idea as I have already completed the greater majority of engine modifcations available for my 3.2L. To the point now wherein which I am considering opting to forced induction and/or a larger Carrera engine as you stated. Hence the idea for 996 GT3 6 piston calipers up front. Slowly but surely I am gearing her for the track as either a 996 TT or 996 C4S will be added to the stable next year.
Old 11-29-2011, 07:03 PM   #4
Crazy Austrian
harryrcb's Avatar
you will also need to install the GT3 master cylinder for the larger volume of brake fluid the callipers need. Easy install.
Crazy Austrian 007
Old 12-01-2011, 07:53 AM   #5
Noted. Thank you, sir!
Old 11-27-2011, 08:03 PM   #6
is it truly that much of an improvement over the stock S calipers/rotors with race pads?
fivepointnine is offline   Reply With Quote
Old 11-28-2011, 07:28 AM   #7
Crazy Austrian
harryrcb's Avatar
Crazy Austrian 007
Old 11-28-2011, 11:58 AM   #8
Hello Harry,
Did you completed the DFI engine transplant into your Boxter..?
how do you like it..?
Old 11-29-2011, 07:01 PM   #9
Crazy Austrian
harryrcb's Avatar
Hello Harry,
I wish, work has kept me away from my project. I will post as soon as it lives again.
thanks
Crazy Austrian 007
