Old 07-04-2005, 08:44 PM   #1
Hunting Idle!!!!
I hope someone out in forum land can help me!! I have a 2000 Boxster which I have been having problems with the idle stabilizing. I have taken the car to Pioneer centres in San Diego twice where they have not been able to fix a thing. Black Forest also located in SD thought the car may have vacum leaks which it did not they also recomended that I replace the MAF which I did, still no luck. I have spent nearly $800 and have not had any luck fixing the problem. I do have an EVOMS high flow intake which I do not believe is the issue but I can not be sure. Can anyone help??
psuball1 is offline   Reply With Quote
Old 07-05-2005, 07:52 AM   #2
Brucelee's Avatar
How unstable are we talking?
I have fixed this issue in the past (believe it or not) with a can of Chevron FI cleaner with Techron.
Old 07-05-2005, 12:20 PM   #3
deliriousga's Avatar
It's cheap, low labor diagnostics! "It might be.... We'll replace that part and if that's not it, we'll go to the next part?". I don't blame him for guessing because most people would choke if he said "I'll figure out exactly what it is before I replace anything. It could be one of 8 different things so it will take me about 4-8 hours to figure it out and you will have to pay me for those hours."
If a mechanic ever replaces parts when diagnosing your problems make sure he gives you the part that was taken out just in case he's wrong. Most parts are pretty darn expensive (especially a MAF) and you have a replacement for later when something really happens or you can sell it on eBay.
When you say you're having trouble with the idle stabilizing, are you talking about a steady up and down movement in RPMs or an erratic movement? What is the range in RPM that it fluctuates between? With your first description, and not looking at anything, I'd say vacuum or sensor too.
Next, how much do you want to get into it? You can do most diagnostics yourself, but it can take a good bit of time and you need a few tools. The tools are 1/3 of what you've spent so far so it's worth it if you are interested in learning the inner workings of your Boxster.
Start cheap like Brucelee suggests with the Techron FI cleaner then go from there.
1966 Wife White/Brown Top
Old 07-05-2005, 03:34 PM   #4
I will start with the Techron additive and then go to the next step.
The idle fluctuates between 500-900 rpm. It never really goes any lower or higher then that.
At this point I really just want the car FIXED!! I am really tired of not having the car work at its best caliber. I know that when I write to the forum I am always able to get the right answers.
Old 07-05-2005, 07:13 PM   #5
Brucelee's Avatar
Talking
You should be able to find the FI cleaner at most auto stores. I buy it by the carton at Costco, as I have a fleet to maintain.
Old 07-05-2005, 08:59 PM   #6
Hopefully the Techron takes care of it. If the first tank doesn't do it, use it fill-up. Depending on how dirty the injectors are, it can take a bit to clean them up.
If it's not normal after two tanks then hope for the "check engine" light with a sensor code that lets you know what's going on.
Good luck!
Old 07-05-2005, 03:17 PM   #7
Bruce can I pick a can of the Chevrom with Techron stuff at any automotive store??
Old 09-20-2005, 06:16 PM   #8
Hey,
I've had the same problem now for a while.
I have a 2000. boxster.
I noticed though if I turn on the A/C, the idle fluctuations are minimized...a lot.
I've only noticed it after the car warms up.
During the winter months in Atlanta, I didn't appear to have had the problem.
Also, it doesn't happen every day and I get no dash lights stating there is anything wrong.
I hope this info is useful. If it continues I guess I'll seek the dealer.
Regards,
Will
willcapp is offline   Reply With Quote
Old 09-21-2005, 06:30 AM   #9
Originally Posted by willcapp
Hey,
Regards,
Will
Where are you in Atlanta? I'd be happy to plug in my AutoTap OBDII program record all of the sensor readings to see what's up. If it's a sensor, it can create the problem but not give any lights because it's still within the limits set by the computer. AutoTap reads each sensor and reports the voltage output or resistance, depending on the sensor. Then you can compare the readings to normal and see what's up.
I'm on the north side (GA 400 corridor) in Cumming. Let me know if you want to get together and I'll try to help if I can.
