Old 07-04-2005, 06:07 AM   #1
Question boxster engine swap options
I was wondering if anybody knows what motors can be put into a 1998 boxster not s, My wifes boxster motor failed and porsche would not step up and take car of the motor because we were not the first owner. So I have to replace the motor and was just wondering if we can put in a 2.7 or 3.2 without major modifications? or has anyone done it before?
Thank you for any information!
evo3m3 is offline   Reply With Quote
Old 07-04-2005, 07:44 AM   #2
Brucelee's Avatar
Talking
Do a search here and you will find numerous threads that will help you.
Yes, this can be done and this is the time to check it out.
However, this is not like dropping an old time small block Chevy into a GM car. The issue is complex and you need some pros to do the work. This will not be cheap but since you are doing an engine anyway ..........
Largely, it is an issue of electronic compatibility but there are some mechanical issues to boot.
Good luck and keep the thread alive!!!!!
Old 07-04-2005, 01:32 PM   #3
Good luck in your pursuit of a new engine for your Boxster .....I have a '98 as well, not giving me any problems.....But I have to ask, what exactly happened to the motor?....and at what mileage did it happen?
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 07-05-2005, 05:24 AM   #4
boxster mileage
Hello,
Thank you for the information and insight. The motor had 59,991 miles on it when it expired. The number 5 cylinder wall let loose and coolant completly filled the left side of the motor and made the car look like an F1 car when the engine blows. It happened at highway speed and in fifith gear with no warning at all, just a big boom and smoke everywhere.
I hope this answers your question about the motor letting go?
Old 07-05-2005, 06:37 AM   #5
Yes, I believe you answered Lou's (bigislandboxster) question quite well...
Lou, I bet you're not going to sleep well tonight are you?
PS - The engine in my MY97 was replaced at 79k two weeks before I bought it.
Old 07-05-2005, 07:40 AM   #6
I was reading another Boxster forum and it appears that there's some failed engine problems. That gets me worrying a little. I have about 13600 miles on mine. How many of you have had engine failure problems here ?
acf53 is offline   Reply With Quote
