10-17-2011, 07:11 PM
2001 3.6 engine build
Finally able to post pictures on 986 forum so here's some of my latest engine build:
10-17-2011, 07:22 PM
Crankshaft & housing, LN IMS ceramic bearing, billet flange & shaft with balanced connecting rods & ARP bolts #4,5&6 installed into crankcase half.
10-17-2011, 07:49 PM
Porscheectomy
You have cool toys to play with. What are you going to do for engine management?
10-17-2011, 08:05 PM
Original Variocam ECU can compensate for the additional airflow, so no changes requred to run in 2000=2002 Boxster or 2000-2001 996
10-17-2011, 08:47 PM
Porscheectomy
So you'll be using the heads from a 3.2 or 3.4?
10-18-2011, 08:07 AM
The heads are from a 3.2 & I think they are the same as a 3.4, I know the cams are the same.
10-19-2011, 09:22 AM
JE Pistons & short pins ready for install
10-19-2011, 05:30 PM
Details, plans, expected output??
10-20-2011, 10:49 AM
I took the flat6innovations M96 engine rebuilding course, so I am basically copying their Stage 1 engine using LNengineering parts. I am in CA so engine will pass CA emissions test easily & add about 40 ft./lbs. torque @ lower rpm than stock. I already have a duplicate engine in my 2000S so if I don't find a 996 to put this engine in soon I will sell the engine to someone else.
10-20-2011, 10:56 AM
Pistons & rings in:
10-20-2011, 11:50 AM
Originally Posted by BYprodriver
Pistons & rings in:
Byprodriver, where in OC are you located? Could be possible to stop by one of these days? Thanks.
10-20-2011, 12:38 PM
I should be finishing this engine tomorrow & have the next engine coming in Monday to start on.
10-21-2011, 04:46 PM
Heads go on next:
10-25-2011, 10:25 AM
Cam Timing set :
10-28-2011, 10:10 AM
Cam Timing set:
11-02-2011, 04:24 PM
Engine oil baffle windows enlarged to aid oil flow to pickup area.
01-31-2012, 10:47 AM
This 2001 3.6 longblock for sale $14,000
02-01-2012, 07:06 PM
02 box s
Pro river, did you do all of the upgrades to chain tensioners,etc? Would you mind listing all of the build specs. 14k. Seems like a good price for someone lookig to upgrade and address all of the failure modes
02-03-2012, 09:49 AM
Sgt, every part of the engine is cleaned & inspected for wear from the case to the bearings & bolts. Anything that can be upgraded is replaced with the best part available. New cam chains, IMS chain tensioner with the external preload spring, LN billet oil pump driveshaft, LN triplerow ceramic IMS bearing upgrade, New IMS chain tensioner paddle, New Cam tensioner wear pads, ARP rod bolts. Lifters & chain tensioners cleaned & tested in new oil heated to 275degrees.All recipricating parts dynamicaly balanced to half gram tolerance. Engine fully prelubed for initial startup including filling oil filter housing & pump & camshafts. Let me know if there are other build specs you are looking for.
Reason: Balance info
02-03-2012, 10:18 PM
02 box s
prodriver,
it seems like a pretty comprehensive build-up. one of the things that i like about jake's builds is that they address all of the "modes of failure." also having 300+hp ain't bad either.
while i don't need a motor right now, it's always good to have resources. buying a motormeister just doesn't cut it. i may give you a call if/when the time comes.
i think i read somewhere else that you've done 2 of the m96 raby builds. did you ever get the other motor on the dyno to see what kind of power it makes? while i'm leary of instant-g's work, it's hard to argue with his logic that the boxster motor makes significantly less hp/lt than the 996. something is choking it down. i am hoping to unlock the missing hp whenever the rebuild time comes. i am curious if your experience shows that the 3.6 makes 300+ as jake advertises.
brad
