Old 09-15-2011, 02:46 PM   #1
Chain tensioner cleaning?
Has anyone tried taking out the external chain tensioners and cleaning them as a remedy for the start up rattle that is common in Boxsters?
If I try cleaning the tensioners, do I have to lock the cams, or can I just lock the motor at TDC and remove, clean and reinstall the tensioners one at a time?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 09-15-2011, 02:54 PM   #2
Crazy Austrian
harryrcb's Avatar
lock the crank and lock the cam then take out your tensioners other wise you could have a problem
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 09-15-2011, 03:24 PM   #3
You must lock down the engine at TDC, and install the cam holding tools before releasing the tensioners. But rather than cleaning them, why not install the newer versions which include a pretensioning spring to help reduce start up noise?
Old 09-15-2011, 04:38 PM   #4
Yeah, I probably should replace them with the updated versions, but they ain't cheap and I am. I'm not even sure that cleanign them would necessarily make a difference.
I have the clatter isolated to the IMS/crank tensioner and I was hoping to just take that one out and clean it without having to go through the cam lockdown drill.
As an aside, the Pelican DIY for replacing the IMSB doesn't require the cam lock, it just uses set screws to lock the IMS before the tensioners are released, so I thought maybe I could get away with just removing one without the cam lock.
Other than the annoyance, is there any long term damage being done by the start up clatter?
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 09-15-2011, 06:48 PM   #5
Not to be unkind to Wayne's site, but I think more than one person has gone astray after reading it by not locking everything down properly before releasing the tensioners. Once released, there is a lot of valve spring derived load on the chains, particularly on a three chain motor, and bad things happen quickly.
A loose tensioner on start up causes the timing chains to "whip" back and forth a bit, which is not a good thing over time as it can weaken chain links, VarioCam components, and even the actual gear on the IMS shaft itself. Sometimes the noise is a combination of the tensioners and wear on the chain tensioner pads (they have a plastic wear surface) on the main pads, or even the smaller pads between the cam linking chains on the five chain motors. When that happens, just replacing the tensioner will not totally quiet the motor unless the pads are changed also, which is a pretty major undertaking as the motor needs to come out.
Old 09-16-2011, 11:23 AM   #6
ryanwise's Avatar
Send a message via AIM to ryanwise
Does anybody know what the ballpark cost is to have the Porsche dealer do this? Also, what would be the mileage for this to be done?
ryanwise is offline   Reply With Quote
Old 09-16-2011, 11:52 AM   #7
Just curious JFP, how much labor is typically involved in removing the engine and replacing the chain tensioner paddles (99610525300). Also, how much additional labor would be required, should the chain guides/ramps (99610517552 and 99610517353) need replacing, as well? I actually just had my paddles replaced, while my 986 was in getting an IMS retrofit kit, clutch, and RMS installed. I am curious to see how much labor other mechanics tend to charge for this work. BTW, here is a photo of the old chain tensioner paddles, as you can see the inner set on both banks was pretty ate up.
1975 Porsche 914
1997 Porsche 986
ubii is offline   Reply With Quote
Old 09-16-2011, 12:07 PM   #8
Realistically, you’d probably be looking at 7-10 hours at the shop’s prevailing rate. The spread comes from the level of the shop’s experience in doing this level of work, how they are equipped, plus these paddles can give you some grief coming apart. It is way easier to pull the engine for this. The guide ramps add maybe another two hours if done at the same time.
Old 09-17-2011, 11:18 AM   #9
After more investigation, I'm not even sure the sound I'm hearing is chain rattle from a bad tensioner. Today I got underneath the car and put a stethoscope on the IMS/crank tensioner and had someone start the car when it was dead cold and I couldn't hear anything abnormal from the tensioner. I'll try the bank1-3 tensioner tommorrow. Could just be lifter/starter rattle.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 09-19-2011, 05:54 AM   #10
check your water pump for giggles. It likes to rattle and emanate noise when going bad.
jbox53 is offline   Reply With Quote
Old 09-19-2011, 06:26 AM   #11
Brand new pump, but I did hear the WP noise when it was going bad, more of a squeak/squeel than a rattlle/claater.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 02-29-2012, 01:59 AM   #12
Hello,
We are having a similar or worse problem over on the Audi A8/S8 D2 forums.
It looks like our pads are almost identical. Infact a lot of Audis and VWs use almost the same pad.
What we have found so far is that our pads have a code cast into them, PA46, this is a material code, PolyAmide 46, its essentially a nylon plastic.
My conclusion is that the supplier who made these pads for Porsche and Audi should have used a better material.
There are at least two much stronger plastics out there that can operate 1000's of hours in temperatures over 200C. Stanyl Diablo, and Duratron CU60 or PAI.
Unfortunatey these huge plastics factories dont want to make just a few pads for one person, but maybe if enough people asked maybe they would be willing to make a batch of pads from one of these stronger plastics.
Another option may be for each person to individually buy a piece of this plastic and find someone to machine it to the correct pad shape.
GOOOO is offline   Reply With Quote
Old 02-29-2012, 05:50 PM   #13
BYprodriver's Avatar
Originally Posted by GOOOO View Post
Hello,
Porsche has upgraded the material for the pads pictured in this thread & it wears much better than the previous parts.
Old 03-01-2012, 02:24 AM   #14
Thanks! that good to know. I have ordered a set of Porsche pads, hopefully they will fit in my S8
Old 03-01-2012, 04:55 PM   #15
jaykay's Avatar
Thanks for this. I may have fallen into this trap. I have a five chain and had thought that one tensioner out at a time would be okay. Can one make the tools necesary to lock the engine?
I can't believe these weren't designed with a preload spring intially. If it is not too much trouble could you post the PN for the revised chain tensioners?
986 00S
Old 03-02-2012, 06:40 AM   #16
Sure, you can fabricate all of the holding tools; the TDC lock pin is a 5/16 rod, and the cam holding tools are just metal flat stock cut to a specific shape, nothing more.
The “old style” tensioners have been totally superseded; you can no longer find them. Any dealer can get you the updated version with the pre-load spring, I'd check with them to get the latest part number as they have changed it a couple of times.
Old 03-02-2012, 07:29 AM   #17
Locking down the cams is certainly the preferred way and guaranteed not to get you into trouble. However, I cleaned my lower chain tensioners by just pinning the crankshaft at TDC and removing, cleaning and reinstalling each tensioner one at a time. No problems whatsoever.
But the tensioner cleaning made no difference with the startup rattle.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 03-02-2012, 07:51 AM   #18
It can be done without locking down the cams, but you assume some level of risk if you do it that way; with everything locked down, there is no risk..............
Old 03-03-2012, 05:11 PM   #19
jaykay's Avatar
Thanks jfp! ...just went to dealer and the guy has no clue as to which tensioner is the latest and will fit my engine...ahhhh yeah
Perhaps just trying to order will filter out the oldies
986 00S
