Old 08-24-2011, 11:48 AM   #1
Screech when the car is very cold
When I start my car, only when cold (as in, it is cold outside and the car is also cold), I get a loud screeching noise. It sounds like a fan belt, but I'm not 100% sure. It doesn't happen when the car is warm, or it not started in a cold morning.
Could it be anything other than the belt? I'm going to check what the condition of the belt is tonight.
rdougan is offline   Reply With Quote
Old 08-24-2011, 12:11 PM   #2
Also check power steering fluid level. Mine was making screeching noise on cold starts when I turned the steering wheel. It was low on fluid.
bmcuscgr94 is offline   Reply With Quote
Old 08-24-2011, 12:14 PM   #3
If it is a weird 1 second screech, it is probably the starter.
If it is a longer screech, I think it is a belt. It can be too loose or too tight. See if spraying WD-40 on the belts help as a temporary fix.
Good luck.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 08-25-2011, 03:50 PM   #4
Take off the serp belt and start when cold. If the screech is gone, then its something the belt is driving. check all pullies, esp water pump, for play.
If the shreek is still there, thenpossibly starter as mentioned above, or something in the motor.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-25-2011, 04:25 PM   #5
I heard it again this morning. It seems to be after you start the car, not when it initially turns over. I will take the belt off when I have time, maybe tomorrow morning, and check it again.
Didn't realise you could do that.
