Old 08-05-2011, 01:25 PM   #1
Red face 987 air conditioning gas weight?
Does any one know the weight of air con gas required to charge/re-charge a 987 system.
Does anyone have pictures of where the air con connections are &
Are the connections easily accessible?
jgwalker98 is offline   Reply With Quote
Old 08-05-2011, 05:00 PM   #2
ppbon's Avatar
The refrigerant ...
... capacity of 134A is 850 gr (30 oz).
The ports are on the right side of the battery, just in front of the cabin filter.
The low pressure (intake) side generally has a green band and is a smaller connector.
The high pressure port is to the left and below the low pressure port.
The dryer is on the left of the battery.
Above you can see the low side port with the green band (falling off) and the black cap in the foreground.
Happy Bostering
Pedro
ppbon is offline   Reply With Quote
