Old 07-26-2011, 01:08 PM   #1
Cat delete
Ive heard that if you delete your CAT'S you will get the engine light from the rear o2 sensors. Is that true? If so what can you do, to not get the engine light.
Hooker012 is offline   Reply With Quote
Old 07-26-2011, 01:30 PM   #2
Opposed to Subie Burble
Overdrive's Avatar
I typed in the title of your thread (Cat Delete) in the Search and came up with this, among others:
http://www.986forum.com/forums/showthread.php?t=23914&highlight=cat+delete
Try it out and see what you find, you might find your answer before getting another reply to this thread.
-O/D
IMSR + RMS
Robbins glass window top
Old 07-26-2011, 01:37 PM   #3
Johnny Danger's Avatar
You can delete the secondary cats on a 2.7 and 3.2 engine without triggering a CEL .
Old 07-26-2011, 08:33 PM   #4
mine is a 2.5
Old 07-27-2011, 05:46 AM   #5
mine is a 2.5
The 2.5 has only one set of cats that are located "mid-stream". Therefore, they can't be removed without triggering a CEL. The only way to eliminate this problem would be to re-map the ecu in order for the vehicle's DME to disregard the change in emissions . Also, going catless isn't necessarily the best choice as far as performance conern. But, that's another discussion .
Old 07-27-2011, 10:27 PM   #6
Idaho Red Rocket 3's Avatar
I'd like to delete my secondary cats on my S. Where can I get the replacement pipes for a reasonable price ?
2000 Boxster S
