Old 10-16-2010, 05:04 PM   #1
very loud screech...aweful
so driving my whip this morning and I heard an aweful screech coming from I believe the front wheel on the right. It was very clear but hard to know for sure where it was coming from. it was far worse than a low pad scratch almost as if the brake dust shield came off and was scraping on the rotor. I feel as if this may be the bearing but most posts do not talk about a loud screech.
any ideas? also it went away after a few minutes and seems to only happen when the car is moving.
Old 10-17-2010, 04:15 AM   #2
Bearings don't screech. They make a rumble.
Could have just been a small stone caught between brake pad and rotor...
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 10-17-2010, 05:20 PM   #3
I had previously thought of that however, this happened two days in a row. now what makes it even stranger is that it happened in the same spot near my house. and if I go different direction it does not happen. weird.
Old 07-11-2011, 04:16 PM   #4
Fuel tank venting system is in this area and does emit some strange noises!
bugman is offline   Reply With Quote
