Old 06-15-2011, 03:39 PM   #1
Torque spec for engine support yoke studs
I'm going to replace the water pump and the motor mount this weekend (fun and games) and I don't see a torque spec for the yoke studs. I'm paranoid because I've stripped the threads in the holes that studs thread into in the past when the stud loosened during dissasembly and I didn't tighten it. Torque spec for the nuts is 34 ftlbs, should i just use that.
And what are your thoughts on oiling fasteners? I've always thoroughly cleaned and lightly oiled all fasteners and then used a torque wrench with no ill effects.
Old 06-15-2011, 05:30 PM   #2
Crazy Austrian
harryrcb's Avatar
Engine mount to engine m10 - 34ft lbs
engine yoke to body m10 - 48 ft lbs
engine yoke to engine m110 - 48 ft lbs
oiling ? no thread lock maybe but not necessary in this case
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
