01-04-2012, 08:26 AM
#61
Originally Posted by sparker
I second a lot of these idea's:
- dependable AOS replacement that doesn't cost what the Porsche Motorsport AOS costs ($700).
- electric power steering kit that doesn't cost what the Porsche Cup kit costs ($2k).
- an intake plenum that doesn't cost what the IPD plenum costs ($900).
As for the BMC CDA, I've already done that
sam
Found this thread searching on the BMC CDA, to see ho others might have installed one. Sparker, would you mind sharing some details on this or even maybe consider making another one of the part that replaces the air box and sits before the BCM CDA for me?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
01-04-2012, 08:59 AM
#62
Originally Posted by rayner@r2specracing
Hey guys.
I was wondering if you could have any performance part made for your car what would it be?
My business partner and I are Mechanical Engineering seniors. We have access to several CAD software packages, and we also have virtually unlimited access to a machine shop.
Post parts that you wish were available for the boxster, and if there is enough interest we will design, and produce the part for you.
We can design virtually anything you need, we just need ideas and feedback.
It can be anything, exhaust kits, intakes, control arms, various linkages etc. Whatever. post it here and we'll see if we can design and manufacture it for you.
I am an Industrial Engineer who just graduated from PennState in May 2011. I also had access to lathes, mills, mandrel benders, welders, SolidWorks and CAD programs, etc. I did the same thing and tried to make my own parts for my car, but then I graduated and I lost access to everything before I got to finish with my parts.
If you can make me a cheap light weight 2ndary cat bypass pipes and Muffler that is just slightly loader and more free flowing than stock, that would be great.
01-04-2012, 01:46 PM
#63
Kroggers - PM sent.
I am a little upset that this thread has died off, started off in a blaze of glory and I was hoping we would have seen some nice new parts by now.
Is there still a chance?
Sam
Australian Carbon Fiber nut
01-04-2012, 06:12 PM
#64
I have been through this multiple times since 1995. The people who *want* and the people who actually *buy* are very different. If 60 people want something done/built, 10 people will actually buy. Sad, but it's a fact of life when it comes to *making* Porsche parts for such niche market.
Took me nearly 8 years to sell off 100 pieces when I had 80 confirmed, then dwindled to 40, then 20.. stuck with 80 parts..
B
01-04-2012, 10:47 PM
#65
Kroggers - PM sent.
Sam
Reply sent...
Kroggers...
11-27-2012, 09:22 AM
#66
Hey guys i know its been along time, the delay has been due to me and my old business partner having some drama. Anyway, he's decided to quit and ive decided to stuck to it.
I have researched the spark plug tubes some more they will cost 120.00 per kit.
Is anyone still interested in doing this?
If I can get atleast 20 people to commit to buying it I will front the money to have them made and when they are ready I'll setup a group buy for them.
Let me know and once again I'm very sorry it took this long for a reply, but hopefully we can finally get some parts made.
11-28-2012, 07:04 AM
#67
Just a thought, but you could probably do well starting a small business and putting it on eBay. Worldwide, I would think you would sell at least twenty sets. Just my 2 cents. Had my tubes just replaced but otherwise I would have been interested.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
11-28-2012, 04:19 PM
#68
Engine Surgeon
There is a good reason why the OEM tubes are non-metallic.
Consider where stray spark will travel from cracked coil packs if a metallic (conductive) tube is employed. As it stands now cracked coils will generally not cause misfires because they stray spark can't discharge into any conductive material nearby. With a metallic tube that is not the case and stray spark will discharge into the tubes and that can create collateral damage, just like it does in Cayenne engines where it kills oil level senders and other electronics when the coil packs crack.
Stray spark can also take out the drivers of other items when it has a path to ground. It is entirely possible that stray spark charging a metallic spark plug tube could even take out the driver in the ECU for that particular coil pack.
Considering how bad these coil packs are with failures, I'd be concerned. With stray spark near variocam solenoids and etc I'd be concerned with those items and their drivers also being damaged.
Just think about it.
US Patent 8,992,089 &
US Patent 9,416,697
11-29-2012, 09:21 AM
#69
^^^^Takes care of that idea!
DEPO Tail Lights
11-29-2012, 10:41 AM
#70
doesn't the 987 have metal tubes that are built-in to the cam covers, but the same coil packs as the 986?
11-29-2012, 11:11 AM
#71
Also, at $120 a kit, could buy a full set of tubes and O-rings twice I think... which would probably last the life of the car and more....
08-12-2013, 11:07 AM
#72
Only assuming that you would anodize those i.e. non-conductive (we went to the same common sense school right?) are these tubes/kit still available?
Changed the plugs yesterday on the car and the oem 'plastic' tubes are shot, cracked, and rather dangerous.... to the driver
05-13-2015, 11:29 AM
#73
you raise an interesting point about the leaking coils creating a voltage arc that shorts out sensors.
I can have the tubes ceramic coated. but that’s an additional manufacturing process. Then the next issue is how much current are we trying to shield from. 1V or 20,0000 V odds are if you have a cracked coil thats pumping out about 20000 v nothing is going to stop that arc it doesnt matter if the tubes are plastic or metal.
I think the best cure in this case is prevention by replacing your coil packs routinely.
Ceramic coating would unlock a big advantage though.
i'd be able to make the tubes from steel which would lower cost and has way better thermal properties than aluminium.
I finally saved up the money to do this so i there is still interest pm me or text me at 9407357295.
and I will have them made. I wont take any orders until I have the parts in hand. I just dont want to invest in parts no one wants
05-13-2015, 03:34 PM
#74
Did my own!
Reverse engineering those is rather elementary lolll and Fun! What the hell... took me half day, from model to turning them in the CNC lathe. Had a hard time finding pre-fab seals however but someone helped me out with that. Week later I had my six custom plug tubes installed in the box!
Screw steel mate, awful convections....similar to those of composites. But cheap to make that's an advantage! Made mine out of 7075 at temper 6 and type II anodized them to Mil Spec 8625 (20µ).
Seals are from an 'unknown' source/material but was told they were high temp o-rings. Unlike on that old solid model I found a minute ago, they are freakish purple colour :/
But then who cares lolll Good news is two years later, still no leaks.
Cheap Cheap, made in China my man $9.99. Good for life!
(those f n oem plastic tubes... mine were leaking hell-juice all over my floor)
05-13-2015, 04:55 PM
#75
So nine86 now that testing is over.......does this mean I can buy a set? If so I want.:dance:
05-13-2015, 05:06 PM
#76
Not for sale Monty sorry bud. R2specracing's idea to commercialize those really... I've just made a set for my box car and mind you, those purple seals I got may have fused to the engine by now. Haven't pulled them out to check since I've installed them so might be a permanent fix I've 'invented' lolllll
Needs R&D on the seal part that's for sure. I remember toasting two @300F for about 2hrs when I got them. They survived the heat but didn't survived a flame - died in less than 10secs.
Aluminum 7075 anodized with an industrial thickness is the way to go imo, that I'm 100% certain. Hope OP will make them that way instead of steel (steel is way too hard to machine also, raise prices).
Out of 6 tubes I've pulled, only two were not cracked or defect. Oil dripping and all.... this plastic tube thing is lame
05-13-2015, 05:56 PM
#77
No worries!!!  I really like the concept though. Fused is much better than leaky and smelly LOL..Thought I'd check since you are responsible for some mighty tasty projects!
05-14-2015, 10:08 AM
#78
awesome work nine six  yeah I could use 7075 its a little harder to source but way better than 6061 in terms of raw strength Thermally though they expand at similar rates. I would have to coat it though because 7075 isnt as corrosion resistant. i like steel because it wont expand as much as aluminium so it will hold tolerance better.
I got my tube in today if people are interested i can get a batch ordered this week. and make a set
I want to make them at my local machinist because I can trace the materials and make sure they arent being made from sub par materials. If my name is going to be associated with something I cant have parts breaking in service it will be a little more but better. Im nervous about using non traceable parts inside an engine.
If i can get at least 5 people to say they will buy a set ill move on it. Ill also beat him up on the price to get us a better deal. its a numbers game though the more units i order the lower the price
05-14-2015, 11:52 AM
#79
I just got back from the machine shop im having them do a quote from different materials and annodized vs non.
Ill update with prices shipped tomorrow.
05-14-2015, 02:43 PM
#80
How about some Titanium lug bolts?
