Old 04-16-2011, 02:47 PM   #1
Is the fuel rail test port a Schraeder (sp) fitting?
I need to test my fuel pressure on my 2000 S and I bought an Actron gauge from Amazon that has a connection for a schraeder fitting. I haven't taken off the cap yet because the big supply house in AZ hasn't sent my new replacement cap yet. Is the Actron gauge going to work?
And secondly can I temporarily use a metal tire stem cap as a fuel rail test port cap?
Dale_K is offline   Reply With Quote
Old 04-16-2011, 02:59 PM   #2
Only if you have also purchased the correct adaptor, the gauge will not connect directly as the end fitting is wrong size...........
And no, you cannot substitute a valve stem cap; you need a new one in the correct metric size with a new seal inside.
