Old 03-08-2011, 02:42 PM   #1
Where to get cat bypass pipes?
Anyone know where I can find Cat bypass pipes for my 2.5L that will bolt up to the stock system? IE these pipes need to have a triangle flange to mate the headers, and straight pipe to mate the mufflers.
Such pipes would also mate up to most aftermarket systems as well (such as Che's).
Can't find any on ebay... And I am definitely not spending 900$ for some when my ebay headers only cost 50.
Someone should make these, I'm sure they could make a few quick bucks. Not sure why Chinese aren't already making them.
mikstew is offline   Reply With Quote
Old 03-08-2011, 02:49 PM   #2
Johnny Danger's Avatar
www.fabspeed.com
Old 03-08-2011, 03:05 PM   #3
****************************************.com
$274 for a set made by Schnell
1983 928 S Euro- fun to work on
2002 Boxster- fun to work on, being able to drive it is a bonus
al83s is offline   Reply With Quote
Old 03-08-2011, 04:23 PM   #4
I would double check that price . I think it might be $274.00 each .
Old 03-09-2011, 06:10 AM   #5
Originally Posted by jojaanbutt
It wouldn't matter if you installed O2 sensors or not. They will just fail after about a month. With or without them, you will get an Engine Light. Not only will you have the light on, the engine will run like crap to the point it will be ruined.
He's right. The 2.5 variant only has one set of cats. Therefore, if you remove them, you'll be catless . This will certainly trigger cel's, and the only way around it, would be to re-map the ecu.
Old 03-09-2011, 09:23 AM   #6
I was under the impression that you can run the sensors open air. You will still get the CEL but it will not run like crap... either way just get a ROW flash, delete the secondary air system and Viola! magic, cat-less with no CEL and no secondary air bullcrap.
or have it remapped like johnny said with some other aftermarket software.
Old 03-09-2011, 09:28 AM   #7
CELs for emissions don't really matter much.
Also, it is ludicrous to charge 500$ for 3 feet of pipe with incredibly simplistic bends and only one flange. I would never buy them from fabspeed. The actual value of the fabspeed pipes is about 50 dollars, including labor if they are mass produced in China.
Old 03-09-2011, 09:39 AM   #8
BYprodriver's Avatar
Stebro makes these pipes @ $300 & Stebro is in Canada.
Old 03-09-2011, 09:49 AM   #9
I have said the same thing. waste of dough-flow.
it seems to me that if the boxster likes some back pressure then maybe, having some pressure bent 2" pipe wouldnt be that bad. you would lose weight have some back pressure and have some great sounding exhaust. and its cheap.
but i could be looking at this simplistically.
Old 03-09-2011, 09:53 AM   #10
I agree. And for $50 they should throw in a Chinese massage as well. Unfortunately, there are very few choices out there - Fab$peed, $chnell and maybe $tebro .
Old 03-09-2011, 12:55 PM   #11
I've got a couple sets available for sale. One is a FVD used set, and one is a new fabspeed style set.. PM if interested...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 03-09-2011, 01:32 PM   #12
if any of you are installing the bypass, can you PM me a price for your existing cat. i just need the rear most cat on the passenger side. mine has a slight annoying rattle. no CEL thank god.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 03-19-2011, 07:52 PM   #13
chauda, do you have a set that would bolt up to a 2.7 '00? I've been looking for a set as well, but don't wanna spend $$$ on the fabspeed stuff...
stateofidleness is offline   Reply With Quote
Old 03-21-2011, 05:38 PM   #14
Still waitin on someone to make some cheap cat bypass pipes. Che, here's talkin to you, buddy.
