Old 05-28-2005, 11:02 PM   #1
DIY??? Rear Tail Light Lens
Can anyone here give me some pointers on how to change my tail lights?
Mikey has some new toys coming. Also anyone ever installed the Optima SC34R Battery?
Mike
2003 Audi TT quattro Coupe
6-speed 225 HP Black/Black/Black
it's stock...no really it's stock man
My other car was a 2001 Boxster
MLegere is offline   Reply With Quote
Old 05-29-2005, 08:25 AM   #2
If you mean just the bulbs, the procedure is outlined in the manual. For the tail light lamp assembly, it's 4 nuts (8mm?) per assembly that holds them in position.
98Boxster98 is offline   Reply With Quote
Old 05-29-2005, 09:37 AM   #3
QporscheQ's Avatar
From what I remember:
1) Take out the carpet section
2) Remove the four screws
3) Unplug the wire harness
4) Slide out light
5) Peel off the seal on the old light
6) Stick old seal on new light
7) Reverse the steps 4-1
Probably will take about 20 minutes if you take your time.
Q
QporscheQ is offline   Reply With Quote
Old 05-29-2005, 01:08 PM   #4
Qporsche
Thanks for the pic's do the black taps holding the liner in snap out?
Mike
Old 05-29-2005, 01:22 PM   #5
QporscheQ's Avatar
I haven’t done this in a long time, but if I remember correctly, the smaller one just snaps on and the other needs to be unscrewed.
Q
Old 05-29-2005, 04:13 PM   #6
I found this. it helps too.
Mike
http://www.smiley.net/boxster/tail.htm
