Old 10-09-2010, 12:07 PM   #1
Maf, P1128, P1130
I have replaced my MAF sensor and an O2 sensor bank 1 before cat because I was getting error code P0133 & P1275. Now I am getting P1128 & P1130. Any suggestions? Doc?
tiger85250 is offline   Reply With Quote
Old 10-09-2010, 03:33 PM   #2
BYprodriver's Avatar
New codes indicate engine is running lean in Idle range which usually is caused by vacum leak.
Old 10-11-2010, 08:47 AM   #3
I had the same codes. My research showed that the most common cause is a bad MAF sensor, usually remedied by cleaning it - which is what worked for me. Given that you just replaced the MAF I would strongly suspect that the new MAF is a bad unit!
Kirk
Old 10-12-2010, 06:41 AM   #4
is there any walk through detailing where and how to check for vacuum leaks?
livin_in_a_boxster is offline   Reply With Quote
Old 10-12-2010, 10:15 AM   #5
I don't know of any but if you can get SMOKE sucked into the intake it should be easy to find. there are machines made for this.
