Old 09-29-2010, 01:24 PM   #1
Crank & Power sterring underdrive pulley upgrade
www.cheetahonline.com
They sell two pulleys for 986. $100 & $200. Sounds good for the 10 + HP & no check engine light.
I figured while you have the compartment opened up, might as well cahnge both.
Anyone tried this?
Sounds like a win/win situation with no down side.
Thanks Rich
RDS911 is offline   Reply With Quote
Old 09-29-2010, 01:31 PM   #2
Underdriving the crank will underdrive ALL accessories, including the PS pump obviously, so also underdriving the PS pulley may be too much.....
Boxster S
Old 09-29-2010, 01:38 PM   #3
Why would it be to much on the power steering side with booth pulleys. Seems like the total rotational mass loss would be good for everything?
Old 09-29-2010, 02:02 PM   #4
Track rat
Topless's Avatar
Oops! A smaller pulley on the PS pump will turn it FASTER, killing the PS pump faster. Maybe not a good plan.
Last I heard Cheetah was not returning calls/emails from customers. Buyer beware!
issues buying from Cheetah Online
DME's for sale
Old 09-29-2010, 02:21 PM   #5
Doc
The "underdrive" ps pump pulley is larger than stock in diameter...
Fluellen is offline   Reply With Quote
Old 09-29-2010, 02:36 PM   #6
Track rat
Topless's Avatar
Hmmmm, I wonder why they put this in their ad then:
"Also, these pulleys are made with a smaller diameter than the stock pulley. This rotates the belt driven accessories at a slightly slower pace (around 10-13% slower). Since each accessory takes power to turn, hp and torque are regained through the "underdriving" process also."
Old 09-29-2010, 03:00 PM   #7
Doc
Yeah, that text part is probably supposed to just refer to the crank pulley. The ps pulley description refers to a larger _belt_ diameter, whatever that may mean... probably a typo as well...
