Old 10-11-2010, 08:43 AM   #21
Engine Surgeon
Great, I look forward to chatting with you. Dean, my operations director will schedule a time that we can talk, I generally do these chats on Wednesday evenings
US Patent 8,992,089 &
US Patent 9,416,697
Old 12-15-2010, 03:06 AM   #22
Hey Jake,
I'm a little confused by the options available via your site.
I see two 450HP options. Both seems based on the 3.6L engine, but two different SKU # ( SKU162491111 and SKU1615911 ) and different prices so I'm assuming they're different products. Perhaps though it is the same product / engine, but just different application ?
SKU1615911 specifically says not street legal, while SKU162491111 doesn't.
If I wanted a 450HP street legal 986, would it be possible to put the SKU162491111 engine in ?
nefarious986 is offline   Reply With Quote
Old 12-20-2010, 04:11 PM   #23
4.0 Ma 101
why not take a 2009 911S motor and install a standard 911 crankshaft with the appropriate rods or pistons to get a 3.996L. I have seen MA101 motors for $16k on ebay, and they already make 385 HP stock! add 5% displacement by stroking it to 4.0L. I also believe that porsche has left some power on the table with the new dfi motors. with 12.5:1 compression and the fuel being directly injected, alowing for the posibility of fuel timing and multiple injections per stroke, there has to be some room to play with, without even needing to increase airflow. I am really looking into a diesel 3.0 from the european cayenne for mine though. I want 1000lb feet of torque! Ha Ha! the engine can come from a toureg or Q7 in a scrapyard here. add some boost, and the 29,000 psi bosch diesel injection is capable of adding plenty of fuel. if the block can take it, then getting the power should be no problem, if someone can crack the code for the reprogramming of the factory controller, or start from scratch, and build a stand alone controller that can also interface with a boxster abs and traction control. you will need the traction control!
and oh yeah, it only weighs 416lbs fully dressed. about the same as a 2.5 or 2.7!
autodoctor911 is offline   Reply With Quote
