Old 07-19-2010, 03:27 PM   #1
Pat
Has anyone tried raising the rollover bar by inserting blocks between it and the body
I know people buy the Brey Krause rollover bar extension for extra clearance, but do you think it's possible to simply carve some chunks of steel or aluminum to fit between the OEM roll bar and whatever it bolts to in an effort to raise it a couple inches? I realize it would involve more labor for installation, but wouldn't that be a more elegant solution?
Of course the bolts would have to be the strongest around, and the fitment would have to be ideal, but assuming those things are dialed in, what other things are there to consider. I don't think it would significantly compromise the structural integrity if done right.
Your thoughts?
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 07-19-2010, 03:38 PM   #2
Rennzenn
j.fro's Avatar
I thought about doing this, and then I had a good look at the rollbar and the car. The problem is that the rollbar is what the top mounts to. If you raise the rollbar, you also raise the top mounts. Unless you're willing to live without the top, it won't work.
Old 07-19-2010, 03:39 PM   #3
Pat
Oh.
Yeah.
I can see how that could cause a problem.
-Chuck Patterson
Old 07-19-2010, 07:02 PM   #4
Besides which, no sanctioning body I know of would ever approve it………..
