Old 06-28-2010, 10:21 AM   #1
Replacing the front right side marker light
I have a bulb out in my 987-01 front side marker light. Need advice as to how to remove the light and replace the bulb.. May just go clear while I'm at it.
Bobby
05 Boxster
04 Rubicon
90 Miata
bnordin is offline   Reply With Quote
Old 06-28-2010, 11:15 AM   #2
for a 987, the side marker light uses bulb 2825 which can be found in any auto parts store for a few $.
To remove, the easiest way, push the front of the marker light backwards towards the wheel. After about 1/4", you can pull the front of the assembly out, slide it forward a bit and then the whole assembly will be free. Turn the plug on the back side 1/4 turn to release. Bulb pulls straight out. Reinstall in reverse. Should take all of 2min to DIY...
Removal the long way is covered in owner's manual
