Old 04-18-2010, 07:33 AM   #2
IIRC>
There is a small microswitch in the inner part of the outer door handle that controls window up/down function. To access you have to remove the door panel, but first disconnect the battery to prevent you loosing a finger if the wndow goes down with your hand in there. (make sure you have radio code).
suburban99 is offline   Reply With Quote
