Old 02-07-2010, 08:12 AM   #1
Help!!! Is boxster goosed!
Hi guys, had a bad week and today has just capped it off! I have a boxster 2.7 tip 2003, Went to help a mate with a flat battery, connected jump leads to my boxster & gave it plenty of revs then it suddenly spewed tons of white smoke out the tailpipe, thought it was on fire! I switched the car off and there is also oil coming out the tailpipe! Has anyone any ideas what I'v managed to achieve here! ;-/ Oh by the way, mates car started and is fine now......
tonkasdog is offline   Reply With Quote
Old 02-07-2010, 08:24 AM   #2
landrovered's Avatar
Massive white smoke from exhaust pipe can be caused by burning coolant. I have never seen oil coming from a tail pipe before but it would indicate a massive failure of a head gasket, cracked block, cracked head, failed turbo or other catastrophic event.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
Old 02-07-2010, 08:28 AM   #3
Thanks, I have a feeling it's gonna cost!
Old 02-07-2010, 08:31 AM   #4
That would be a safe assumption. It is going to cost.
Old 02-07-2010, 10:48 AM   #5
Track rat
Topless's Avatar
Possibly just oil overfill or failed AOS. You are not dead yet. Pull the dip stick and look for signs of oil/coolant mix. If the oil is still clear and clean and your coolant is still clear and clean she has some life left in her. Good luck!
Old 02-07-2010, 10:53 AM   #6
Hi Topless, thanks for the reply. She was only serviced (96k) 2000 miles ago and the oil was checked yesterday. Someone else on another site mentioned the air/oil seal also, i just hope this is all it is! Thanks again m8
