Old 01-24-2010, 05:39 PM   #1
Cycles needed to satisfy the monitors?
Using an Actron CP9125:
When I plug in the Actron CP9125 to check my CEL I get the following codes:
P0410, P1411 and P0430.... these I know and understand.
I also get Inspection / Monitor status of: Misfire, fuel, comp, etc. and a Ready status of A/C Evap etc.
Per the Actron book, the Monitors Incomplete and Ready Monitors are read from the car’s computer and the Incomplete indicates that the car’s system has not run a sufficient number of “cycles” to flip over to a “Complete” status.
Does anyone know how many cycles/miles/hours need to be run by the car in order to “Complete” a monitor status in the Porsche computer? I’ m looking for the exact number or an explanation, not just someone’s guess.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 01-24-2010, 09:52 PM   #2
Completing OBDII monitors is not a question of "how many drive cycles", it's a question of how you drive it to make the monitors run. There is a lot of 993-specific advice in this thread:
http://forums.pelicanparts.com/porsche-964-993-technical-forum/260106-ca-smog-993-obdii-readiness-sai-4.html
It sounds like the Boxster OBDII manual will tell you exactly how to drive the car to get the monitors to run. I'd look at that if I were in your situation.
Blue-S
2000 Boxster S 6-speed - Ocean Blue / Savanna Beige
* 9x7 short shifter * Pedro's enthusiast mount * Carrera Ltw. wheels * Stebro bypass pipes
* M030 coming soon! *
Blue-S is offline   Reply With Quote
