Old 01-12-2010, 11:16 AM   #1
Volume speed feature disables speakers
I'm still a fairly new owner of my 2000 Boxster S and I have a problem when the top is down where it seems that at a certain speed the speaker volume increases and shortly after the speakers cut out. Radio still appears to operate - just no sound. If I turn off the ignition, remove the key and start agin it seemes to reset itself and I have sound again; only to cut off again. Top up - No problem.
Any ideas - Thank you!
wdlnds09 is offline   Reply With Quote
Old 01-13-2010, 11:46 AM   #2
Check the setting for the sound differential. It could be turning the volume up too high and it cuts out to protect itself. My home system does that if I go to a channel with high dB from one with very low power.
And WELCOME.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
