Old 12-17-2009, 07:08 AM   #1
Where are the coil packs
fellas, that might be a dumb question, but the 1128 code I get occasionally says something about misfire blah blah blah and I've seen a lot of posts recently about swapping/replacing coil packs for that bank/cylinder.
where are these coil packs and what do they look like? is there 1 per cylinder, or 1 per bank?
also, with that CEL code in mind, what would I swap to test the coil packs?
i was leaning towards a vacuum/exhaust leak (which I know i have), but thinking I might have the mechanic check these coil packs as well
stateofidleness is offline   Reply With Quote
Old 12-17-2009, 08:33 AM   #2
The coil packs are on each spark plug located on both sides of the engine. There are six of them total with 3 per side. Search spark plug change and you'll see good pics and how to get to them.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
