-   -   Headlight Yellowing (http://986forum.com/forums/performance-technical-chat/22936-headlight-yellowing.html)
mmontfort 11-30-2009 02:06 PM
Headlight Yellowing
Does anyone know how to take the fronts off the headlight assemblies so they can be buffed out to get rid of the yellowing. Mine are yellowing at the top on the inside. I used a headlight polisher on the outside and it really did nothing. The Bentley book says nothing about how to do this. Can it be done? :confused:
JFP in PA 11-30-2009 02:32 PM
No, you would have to break the housings apart to do that. Time for new assemblies.............
Lobo1186 11-30-2009 02:38 PM
tint them yellow and be cool
Gent 11-30-2009 02:59 PM
Are you sure it's the inside you need to get at?
There's a great DIY at renntech on polishing the lenses: http://www.renntech.org/forums/index.php?showtopic=24285
(I think you have to register though)
If you still have to get into the headlights, modders have been doing this for years with other cars. Nervous work, but somebody figured out the boxster "recipe" over here: http://www.boxsterforum.com/forums/showthread.php?t=16149
How did I know about these? I have the same issue. Just parked mine for the winter, and I'll be looking into this myself.
manolo 11-30-2009 03:40 PM
This guy at RennTech says they can be separated in the oven. It sounds dodgy to me but he has the pictures to prove it. I might try this on my old headlights to see if I can do it without warping them, but your mileage may vary.
http://www.renntech.org/forums/index.php?showtopic=30290
gschotland 12-05-2009 01:28 AM
Lots of good used headlamp units on eBay for $75-$150 each. Why not simply swap yours out for better ones and then sell yours for whatever you can get? Can't imagine you'll be out more than $150 when all is said and done. Think of what your time's worth - and how much you could end of spending on products of questionable value - screwing around with your current units?
Blkboxster 12-11-2009 08:06 PM
Dnt do it...
idheaton 12-13-2009 07:09 AM
I think I read that yellowing of the lenses can be attributed to running aftermarket bulbs that are higher wattage than the recommended 55W and that they are actually being burned which is causing the discoloration.
You might want to check your bulbs and possibly change them to at least stop any further damage if this is the case. If they are in fact burned you are probably looking at replacement since they probably can't be buffed out even if you break them open.
