Old 11-23-2009, 10:30 PM   #6
JonnyBGood's Avatar
Originally Posted by Spanky
You could have a bad ground. Next time you have the problem, hook a jumper cable from your ground on your battery to the frame or even the engine if your cables will reach. If it starts then this could be your culprit.
I have also had the nut on the power wire from solenoid to starter come of a starter before (not my porsche) which created intermittent starting problems as well.
Good luck!
Chris
I'll try the clutch switch first then try this if that doens't work. How in the world do you fix a "bad ground"?
"Insanity: doing the same thing over and over again and expecting different results." -- Albert Einstein
JonnyBGood is offline   Reply With Quote
