Old 10-10-2009, 08:45 AM   #1
boxster starting problem
Turn ignition key and all dash warning lamps work. There is a fuuny noise from dash and electric windows judder slightly.
Battery checks out and is charged. Have triied to start in park and neutral but no joy. Car started fine 4 hours earlier.
HELP
kelidan is offline   Reply With Quote
Old 10-10-2009, 02:06 PM   #2
I had something similar and it turned out to be a failing clutch switch. however, since you mention putting it in "park" and "neutral," I assume you have a tip??
otherwise, strange electrical can sometimes be a failing ignition switch. have you ever replaced yours?
are you sure the battery is ok (I know you said it "checked out," but I'm not sure how you tested it).
jjanari is offline   Reply With Quote
Old 10-11-2009, 06:50 AM   #3
reply to jjanari
Thanks for response.
Yes car is tiptronic.
Checked battery with voltmeter then connected charger and full charge led indicator lights up on charger
thanks
