Closed Thread
Old 09-27-2009, 05:43 PM   #1
Engine Surgeon
Lessons learned: Buying a "used low mileage engine"(must read)
The story I am about to share here is still ongoing and continues to unfold. It rivals some of the stories that potential clients have shared with me over the last few months and because of that I felt that I should share it.
This is long and detailed, (17,881 characters) and lots can be learned from reading this post and being objective during the purchase of any "used" engine.
Before getting further into the story I'll state that with the knowledge of the M96 engine's internals being more manipulated these days these stories are becoming more wide spread. More and more people with limited knowledge and experience are making repairs and some of those "repairs" are being mis-advertised when engines are being sold. This is mostly occurring with, but is not limited to Porsche dismantlers. These dismantlers take the parts we'd throw away and take out of service, then patch engines up and sell them as "used" engines. They do this to limit their liability and so they can "play dumb" about the engine when it does fail. This is great for their profit, horrible for your wallet, your car and your morale.
So, here is the story, listen closely and don't let this happen to you. If it does no one will care and you'll lose your money like my client did, all that will happen is people passing the buck onto someone else.
One of my best clients who had the highest output 3.6 engine that we've completed to date experienced an engine failure due to the oil pump drive key. I posted that failure point elsewhere in this forum last week, if you'd like to see the pics. Till this point we'd never experienced this mode of failure, or heard of it and attribute it to the extreme throttle response that this engine had. As I type this a billet chromoly version of this drive is being machined to remedy this issue with all my future engines as we continue to make the M96 a thoroughbred.
This client wants to build a second Boxster next year anyway,(with a Stage IV Turbo FSI engine) so while I had his 3.6 apart on the bench enhancing it, he decided to buy a used engine for his track car to finish the season. Then next year he'd build a new car using this (second/ spare) engine as a platform for it.
I supported this decision and agreed to pay for the shipping of the engine that he'd buy to have it shipped to my facility and I also agreed to supply the necessary labor to install this engine at a seriously reduced cost, basically free as a sponsorship and to further the relationship/ friendship we'd built over the past year.
So, the client finds a "used low mileage" engine on Ebay. It was advertised by an individual that claimed it has 20XXX thousand miles on it and was pulled from a Boxster S that had been totalled in a front end crash. There was no mention that this engine had been repaired or that a wrench had even been put onto it's components after it left the factory, the seller disclosed that he had resealed the cam covers, lubed the valve train components and replaced the AOS to prepare it for conversion into his Boxster. He stated that he chose not to install this engine into his Boxster because he found a good deal on a broken 3.6 engine that he wanted to install into his car instead. The seller then stated it had come from a Porsche dismantler "In California".
The story seemed legit and the seller was someone I had some conversation with in the past, and he was a member of several forums that I frequent. We had no reason not to believe him and the pics of the engine illustrated it to be very clean, easily capable of being a 20,000 mile low mileage engine. The price was right, so my client asked the seller a series of questions and he was told what he wanted to hear so he fired off a cashiers check to the seller and we scheduled a pick up of the engine from it's mid-west location at my personal expense.
When the engine arrived I was impressed!! Very impressed! That was until I got within 5' of it and noticed that it was entirely too clean.. I looked closer and saw evidence that wrenches had been on the head bolts that were external to the cam covers. At that point I looked at the tabs on the head gaskets and could tell they were aftermarket and were also entirely too clean, without having any grit what so ever in their folds. This told me that someone had pulled the heads off this engine and that scared the heck out of me immediately because I know how few people can do this work correctly.
So, I call my client and start taking pictures. I instructed my team to complete a leak down test on the engine and start looking for other signs of intrusion by a foreign party.. At this point we used a borescope to peer inside the cylinders and inside the cam covers and everything appeared as advertised with the valve train well lubed and the AOS being brand new. The leak down test was successful and the worst cylinder showed 3% leak down, not bad for an engine with dry cylinders that hadn't been ran for a good while. The cylinder heads o the engine were too clean and basically appeared to be new and so did the hardware inside. Based on the parts used, we could only assume the labor was done by a competent and knowledgeable M96 technician. (WRONG read on!)
I contacted the client and told him that I was uneasy about status of the engine with the evidence that I had in hand. Since the story matched up pretty well and because he didn't have time before his next track event to have us pull the heads and etc we mutually decided to add a low temp T stat and an IMS retrofit bearing as preventives and hope that the story on the engine was true and the results would be positive as we didn't have time for any other hiccups.
So, I pull the IMS bearing and take a look inside, the IMS was starting to show wear but they all do, so I replaced it and peered inside with the borescope and found nothing else alarming inside.. We pulled the oil sump and cleaned the oil pick up tube and made a change to the scavenge oil return baffles/ de-foamers for track use
and sealed it back up.
After this was complete my team then installed the engine and beckoned me to start it up for the first time, as standard operating procedure. As soon as it fired it had 3 cylinders and threw a flashing CEL, I immediately knew what had happened! We pulled the codes from the ECU that reflected misfires on cylinders 4,5 and 6, exactly as I had suspected from the way the engine had ran.
At this point I knew we were ***ked because the person who had never set the cam timing on an M96 engine had been working on this engine. I knew this because this was the first mistake I ever made on an M96 when I had no direction and no no one to ask... It was clear that this person followed the instructions that came with the cam timing tools, but those directions do not include the fact that the engine must be rotated exactly 360* between setting the cam timing on the 1-3 bank and the 4-6 bank. This clearly illustrated how lost this person was, that really made us uneasy but luckily no damage was done and a cam timing alteration would be a time consuming, but effective means of repairing the issue. We had looked at the cam timing while we were being very objective about the engine before install, but since it was exactly 360* out and only on one bank nothing jumped out at us.. If it would have been 45, 90 or 120* out we would have seen it and it would have effected the leak down test- we would have found that.
So.. this happens on a Friday afternoon and now the engine is in the car.. I call my Wife and tell her that I'll be pulling a 3rd all nighter for the week and that she won't be seeing me till Sunday. I stay and finish the cam timing procedure to stay on track so my client can have the car delivered on time for his track event... I do this work without pulling the cam covers and risking another leak that we didn't have time to repair... I finish the night by sending the seller a nasty gram about the idiot that had been working on this engine, an engine that he maintained had NEVER BEEN REPAIRED... This "Phantom Mechanic" sucked even more than we had imagined... At this point my client assumes that the "phantom mechanic" was none other than the "seller" and I agreed, that it made sense because he was going to reassemble his own 3.6.
I pull this off and have the car back together for testing on Monday morning... The engine fires up and runs beautifully.. I pull the 3.6 flash from the ECU and within 3 runs I have cooked up a flash for this 3.2 that made 249 RWHP. Our worries had subsided and now it appears that our re-cam timing of the engine coupled to whatever these people did made a big power gain for the engine.. I continued to objectively dyno the engine while under full telemetry of my data logger and Dyno.. We monitored intermix and coolant levels and look for other signs of leakage- all was normal.
So at the end of the day I unstrap the car and take it home for a 83 mile round trip test drive before having my assistant, dean deliver the car back to it's Owner in time for the track day. My test drive is uneventful, the car was blistering fast and coolant temps never reach 190F. I get home, look under the car for leaks and check the coolant tank for intermix, still being very objective. I find nothing, all is well.. The next morning I drive the car to the shop, do one more dyno verification after the ECU had time to adapt to the engine and flash, the result was 251 RWHP and even more torque than the day before. This proved that there were no issues with the engine so we prepped it for shipping. It was clear that we had overcame the challenges and the client was going to make his track day.
The next day I had my assistant, Dean show up at 0400 to use my personal truck and the client's trailer to rendezvous with the client's friend at the 1/2 way point between my facility and the client's location. This resulted in a 600 mile drive for both parties, meeting in the middle and driving home. I didn't charge my client a dime for this for time or labor.
When the car arrived at its home location my client took it to the indy shop that has been maintaining the car for as long as he has owned it to have the alignment checked and the key switch replaced.. They did this work and took the car for a 35 mile test drive, they were also very impressed with the power and they did not see any leaks. They specifically checked for intermix in the coolant and the oil, and ZERO was present, they looked over our work and gave the car a clean bill of health...
Now is where it gets interesting:
The client shows up at their shop to grab the car.. He gets 10 miles down the road and a huge cloud of smoke emits from the exhaust system.. He limps back to the shop and they check the AOS, but it tests fine.. The problem is attributed to the accusump system engaging in a sharp corner and dumping oil into the engine under deceleration, (which has happened before) because there were no other symptoms and at that time there was no intermix and nothing wrong with the (new) AOS.
The client calls me and I concur with the Indy shop's account of the issue... He drives the car home with the accusump turned off with no recurrence of the issue.
The next day he drives several hours to the track, towing the car... He gets to the track and makes 1/3 of one lap before the engine does the same thing again..Huge billows of smoke out the exhaust system.
This time the accusump was still disabled, so there is no way the issue could have been the accusump...
The client calls me and I walk him through some checks.. He pulls off the hose leading from the AOS to the intake manifold and finds it filled with oil, like a failed AOS, but then he tells me the oil is really thick and milky, like a milkshake... At that point my stomach hit the floor and he loaded the car up and drove several hundred miles back home, dropping the car off at the Indy shop for another diagnosis... He was disgusted. I was disgusted. We had been lied to and we had both wasted hundreds of miles and thousands of dollars.
Very quickly the worst nightmare is confirmed, the coolant tank was filled with intermix... Something had failed big time.
So the next day I talk to the Indy shop and answer their 20 questions about the engine. This shop has been wanting to learn more about the M96, so this appears to be their opportunity, but at the cost of the client. I agreed to share tools and knowledge with them to support this issue and make it right, no matter what that may be (for free).
We agree that the intermix issues were probably emanating from the head gaskets and/ or a related issue like a slipped sleeve. At that point it was clear that the engine had an intermix issue that took it off the road prior to the failure and someone thought it was nothing more than a blown head gasket. They replaced the head gaskets, swapped out the heads with some that were damn near new castings and then set the cam timing- the only problem was that they did all of this the wrong way.. They basically sucked with their procedures and myself and my client have had to absorb this... Read on..
So... The Indy shop begins to pull off the cam covers and the heads looking for the culprit. My client (who is a Heart Surgeon) takes a day away from the office and heads down to photo document this procedure and the results. With the cams removed the head bolts were then started to be removed.... This took LESS THAN TEN FOOT POUNDS OF TORQUE to accomplish!!! The heart of the issue was that the "Phantom Mechanic" didn't freakin torque the head bolts correctly!!! What an idiot!! The head bolts were not even torqued to the point that they are prior to applying the additional "degrees" of torque specified for the head bolts.
By this point lots of mis-advertisements have occurred and lies have happened at some point, by someone. At this point its clear what the issue was and a round of emails have been well under way between the seller, the buyer and myself about what has happened and what should be done to make this right. I have maintained that this engine was not as advertised and was much more than just a used engine out of a salvaged car. No frontal collision would have required head gaskets to be replaced, heads not properly re-torqued and cam timing improperly set!
So.. The seller maintains that he has no responsibility for this engine, every email that has been sent to him has been partially responded to and the only info he gave us about the "salvage yard" that he sourced the engine from is that "He has called and emailed them with no luck". We have asked him to supply their contact info to us along with is invoice number to quantify that he did indeed purchase the engine from them, but he has not done this.
Jake Raby is offline
Old 09-27-2009, 05:44 PM   #2
Engine Surgeon
A second post was required to finish the story, the forum limits single posts to 15,000 characters-
Continued:
The seller is very apologetic about what has occurred, but thats simply not good enough, action is required to make this right, because "Phantom Mechanics" don't exist and we'll maintain that the salvage yard and the "rest of the story" doesn't exist until some form of formal invoice is produced where this engine was bought from a "salvage vehicle". Even at that point someone owes my client reimbursal due to false/mis- advertisement, especially when my client asked the seller specifically about any repairs that had been made to this engine..
After its all said and done, the shipping of the engine, shipping of the car, my (at cost) labor to repair the cam timing and the Indy shop's labor to fix this huge cluster will COST MORE THAN my client paid me for his 3.6 big bore engine!
It goes further... My part isn't over:
The cylinder heads from this engine are on their way back to me to be inspected to ensure that the "Phantom Mechanic" didn't do anything to screw up the heads that will come back to bite the Indy shop, my client and me in the ass for a FOURTH time!
So when these heads arrive I'll drop everything that I am doing and process them.. I'll then give (a value of over 700.00) to my client a set of 24 upgraded lifters (since 22 of his were bad!) and I'll pay the shipping to get all of this back to the indy shop along with a pair of free head gaskets and head bolts to make sure we can get this poor client back on the track for his last two events of the season.... No one has asked me to do this, its what I feel he is owed for all of this BS especially since the seller isn't manning up to the situation
So this is just very detailed account of how a "used" Porsche M96 engine can be mis-advertised as a "used low mileage" engine when it has actually been subject to half assed repair by a total idiot, then sold with false claims to an unsuspecting buyer.
This is what is happening to the majority of "used" engines and thats why you can't ever trust one when purchasing it.. Even those purchased from people you have had contact with that seem to be genuine, with good intentions.
Remember, what is too good to be true; really is too good to be true..
Now, I have not disclosed the identity of this seller and I hope that hell read this and step up to the plate like myself, the buyer and the Indy shop have to make this situation right. If he chooses to maintain that he has done nothing wrong and that the engine was advertised accurately, further action will be taken.
He has wasted a lot of our time and money, so its only fair that we reciprocate that..
Where I come from Porsche enthusiasts don't do this to each other...
Think twice before you buy a used engine, more than likely it had a failure and was patched up by someone that has zero M96 experience, like this one was.. You'll be left out in the cold and the seller won't do anything to relieve the burden that he has created for you... And your mechanic will probably get stuck where I am.
Old 09-27-2009, 06:04 PM   #3
Jake, that was a good read. Thanks for the info and the advice. Even us shade-tree guys have to make sure we do the right thing when working on our cars. I know I try to and have the cuts, bruises and dirty finger nails to show for it too!
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline
Old 09-27-2009, 06:21 PM   #4
Porscheectomy
Sounds like it was making alot of power, any thoughts as to why?
blue2000s is offline
Old 09-27-2009, 06:30 PM   #5
Engine Surgeon
When I had to reset the cam timing I altered it to my specs... The other reason was due to the under drive pulley, our exhaust system and the ECU flash that I have been perfecting for the "stock" 3.2 with this cam timing for over a year now.
Now the other reason is because the heads had been re-machined, thus bumping up the CR and boosting power..
Another 3.2 I had in this car made 247 RWHP with the same components, with heads that had been remachined .010
Old 09-28-2009, 12:05 PM   #6
damn Jake... that post made my knees buckle!
jbox53 is offline
Old 09-28-2009, 12:34 PM   #7
Topless's Avatar
This story could be applied to a whole host of things for sale on ebay. (Ask Randall about nice used Boxsters). Let the buyer beware!
Topless is offline
Old 09-28-2009, 12:43 PM   #8
Engine Surgeon
And you didn't even lose any money in the deal!!
The seller maintains that he knew nothing and the engine was sold "as is", though it was mis-represented entirely.
So, people here will know who he is soon enough. He seemed like such a genuine guy, but those are always the snakes in the grass that you have to watch.
Old 09-28-2009, 02:38 PM   #9
this may help someone:
"The most common type of implied warranty is the warranty of merchantability. That means that the seller promises that the product offered for sale will do what it's supposed to. An engine that will run is an example of a warranty of merchantability. Breakdowns and other problems after the sale don't prove the seller breached the warranty of merchantability. A breach occurs only if the buyer can prove that a defect existed at the time of sale. A problem that occurs after the sale may be the result of a defect that existed at the time of sale or not. As a result, a dealer's liability is judged case-by-case.
Of course, in your case, it sounds like there was a defect at the time of the sale. Before taking your case to court, you should put your grievance to the seller IN WRITING and formulate it under the pretense that you will be seeking litigation if this last attempt at resolving it amicably is denied. If that does not work, you may take this issue to small claims court since it likely falls within the small claims court cap amount in your jurisdiction."
Read more: http://www.justanswer.com/questions/1kt25-bought-engine-car-four-months#ixzz0SRYTMUV5
jbox53 is offline
Old 09-28-2009, 05:35 PM   #10
Engine Surgeon
The purchaser has determined that persuing this in any form just isn't worth the time. He'd much rather my efforts be expended on making his Boxster a GT3 killer.
So this person will go on as a part of our community, mingling with others that have no clue that they may be the next one that he decides to take advantage of, then pass the blame onto others....
So, allow this post and our expenditure of funds to be nothing more than a reality for those who feel a used engine is a viable means of solving the issues associated with an M96 engine failure.
This will only get worse as people get a few special tools in their hands and think this engine is a ssimple as a Briggs and Stratton... More will be screwed and for much more money than we were.
You have been warned.
Old 09-29-2009, 05:43 AM   #11
Very interesting read...sends chills down my spine.
The seller knows who he is...what goes around, comes around.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
jmatta is offline
Old 09-29-2009, 06:40 AM   #12
Engine Surgeon
Yep.. And he has read this post and responded to me via email. He isn't happy- I don't care.
He threatened libel if I disclosed his identity... Imagine that.
Old 09-29-2009, 10:33 PM   #13
Obviously if he saw this thread then he is surely a member of this forum. I for one do not stand to associate with people like that.
It is my opinion that someone like that should be banned from this forum, and if it were legal I would tar and feather him and ruin his "good reputation" with the truth.
PlayersExpress is offline
Old 09-30-2009, 12:57 AM   #14
Story Still Unfolding
The story of this Motor - "Motor C" as Jake and I refer to it, continues to unfold. When the final Chapter comes to a close I'll post my version events - along with names, dates, data, and dollars.
The "Purchaser".
pcs5978 is offline
Old 09-30-2009, 05:27 AM   #15
Brucelee's Avatar
"Under the doctrine of caveat emptor, the buyer could not recover from the seller for defects on the property that rendered the property unfit for ordinary purposes. The only exception was if the seller actively concealed latent defects."
Then again, you have to prove the concealment.
Personally, I wouldn't buy a used engine, certainly, not from anyone on ebay.
Hope this turns out well and thanks for the story. Good one.
Rich Belloff
Brucelee is offline
Old 09-30-2009, 06:22 AM   #16
Engine Surgeon
Bruce,
It isn't going to turn out "Better". The damage has already been done, the seller has gotten his money and according to his pictures on facebook he has been partying his ass off at some local clubs-probably with the purchasers funds.
The purchaser is now going to miss another event due to this BS, which entirely defeats the purpose behind buying engine "C" now and finishing the season. The purchaser has also faced more financial responsibility related to this with his local Indy shop.
Yesterday I received the cylinder heads and worked until 2330 last night to get those heads inspected and turned around ASAP in hopes that we could get the purchaser back on the track for his next event.
Unfortunately when the "Phantom mechanic" only torqued the cylinder heads to 10 foot pounds, totally disregarding the proper cylinder head torquing procedures the cylinder heads suffered more than just some blown head gaskets and intermix- Now the cylinder head sealing surface is no longer true enough to successfully have new gaskets applied without them blowing almost immediately, repeating this issue.
The CBM machine needed for this is tied up until Monday, so we can't turn them around until after this time. That means the event will be missed.
Now is where it gets even crappier:
These cylinder heads were recently machined when they were pulled and replaced by the "Phantom".. That means that according to how much material needs to be removed to get the head sealing surface straight again could determine the structural integrity of the head casting. These heads don't have many "Lives" in them when it comes to resurfacing without compromising strength. The other issue lies in the fact that the combustion chambers of the 3.2 heads are very small and due to their shape any amount of resurfacing results in boosted compression ratios, which is great in some ways, but in others it means the heads are weakened and won't last very long, especially under track conditions.
Having seen these heads and the fact they had been resurfaced now explains why the engine made more power than it was expected to and maintains the title of the strongest 3.2 we've ever seen in stock form.. It was due to the boosted compression ratio that was the byproduct of the cylinder head resurfacing. Now why were the heads resurfaced?
Now the real question that we are trying to answer is what made the "Phantom" pull the cylinder heads from this engine in the first place?? Was there a cracked head, blown head gaskets? Did the engine get way too hot? I have to look at these heads very closely and understand why they were pulled and what has been done to them so we don't end up right back where we are now, after even more money has been spent, and more events missed..
...and of course I'll have to do all this work for free, because the purchaser should not be responsible for paying for even more BS.
I am a very objective person and generally I don't trust anyone until they have proven themselves to me. This reservation keeps me from ending up getting the shaft in most situations. When the "purchaser" first enquired about this engine he forwarded me the emails from the seller for my review. I immediately noticed the seller's name and knew that he had been in contact with me in the past concerning these engines (generally looking for free advice because he was as lost as every other soul working on an M96 engine) as he worked on his 3.6 and tried to reassemble it.
I told the purchaser that I had communication with the seller and that made the purchaser and myself feel better about buying an engine across state lines, off of Ebay.. At least we knew the person and knew they were real.
And guess what, he still screwed us.
If we had known this engine had been purchased from a dismantler, or that a dismantler had EVER TOUCHED IT, we would have NEVER purchased it- period.
The seller will maintain that he offered a refund for the engine and he did- BUT this was only done after the purchaser had spent MORE MONEY on the engine's install and repair than the price of the original engine. The seller was smart and avoided our emails directly on the topic of reimbursal until he was positive that the purchaser would not return the engine for his "refund". At the point the seller offered the refund it was CHEAPER to repair what we had.
There is at least one person on this forum who will take advantage of you, let that fact be known. He is a really nice guy, until he gets your money and you have a problem.
People don't take advantage of me or my friends/ clients. He screwed the wrong two guys.
Old 09-30-2009, 11:18 AM   #17
Engine Surgeon
It continues to unfold:
Further "warm" pressure testing of the cylinder heads this morning showed a crack in one of the cylinder head castings.. Whether or not this crack can be repaired with our casting repair processes is still not clear.
At temperature the crack revelead fluid loss at as little as 5 PSI pressure..
Its now clear that this was the root of the issue that took this engine off the road and put it into the hands of the "Phantom"... Since this person didn't know any better and since the symptoms appeared to be just like a head gasket failure the "Phantom" had the heads resurfaced then simply threw on some new head gaskets. He then barely torqued the heads back in place and screwed up the cam timing.
Then sold it.
Needless to say, we are more furious than can be imagined.
Old 09-30-2009, 12:11 PM   #18
This kind of happened to me when I bought a 3.6L from New York as they said the Carrera only dinged up the oil pan and the insurance bought the guy a brand new engine. Installed my 3.6L and the cam timing was all off, luckily the car has been driving fine for about 2,000 miles now other than a blown water pump. The shop that did my work has been racing Porsche's for 30 years and knew what they were doing like you (Autometrics in Charleston). Good post Jake.
BoxsterLewis is offline
Old 09-30-2009, 12:51 PM   #19
Rub it in!
Jake, I sure do appreciate your dedication to doing things right, not fast, not cheap, or not to make your company look good. Thanks for sharing this horror story.
I take it the seller of the POS M96 motor is a forum member. How very sad.
RandallNeighbour is offline
Old 09-30-2009, 01:13 PM   #20
Just from some quick looking in the classifieds I think the engine came from a non-daily visitor of this forum....one of those 'parting out 00' 3.2L 986 S' dude that list what they have and never come back.
blinkwatt is offline
Closed Thread
