08-30-2009, 08:35 AM
Engine Temperature Indicator
Just got my first 99 Boxster with 75K plus mileage. It ran very well. I noticed the engine temperature indicator showed above 180 mark. It was more like 205-215.
Is it normal for a Boxster after 15 minute cruising? Any comment and info is greatly appreciated.
08-30-2009, 08:40 AM
No, you have a problem some where......................
08-30-2009, 09:05 AM
07 Carrera S Cab
That is not normal. After warm up, my car's temp gauge points exactly between the 8 and 0 at 180, and hardly ever moves from there, even after hard driving. Something is amiss in your cooling system, and I'd look into it.
08-31-2009, 05:07 AM
Wow, if the gauge is showing 210*, I wonder what the real temp is?
We all know how "accurate" the factory gauge is, afterall.
Definitely get your car looked at before it melts down.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
08-31-2009, 07:43 AM
Since the engine temp gauge above 180 is not normal on a Boxster, what do you think the causes of this? I read some of your posts regarding T-stat 180LN vs 160LN. Should I change T-stat 180 LN to 160 LN in order to lower the engine temp?
08-31-2009, 08:01 AM
Often it's something simple when the temp is just a bit above where it should be. A stuck thermostat has always been culprit #1 with my cars. # 2 is a blocked radiator or disabled electric fan....
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
08-31-2009, 08:07 AM
The very first thing you should be doing is get the car to someone with an OBD II scanner capable of real time data capture (PID); have them check what your water temp really is at before you puke something major.
You could have a bad dash gauge, temp sending sensor, water pump, externally blocked radiators, or dead thermostat; you need to start eliminating items one at a time rather than just swapping out parts
08-31-2009, 09:44 AM
JFP - Thanks for your suggestions. I reviewed the previous owner 's service records and found both the water pump & thermostat was replaced last year. I would think that they should not go bad already.
Where can I buy the OBD II scanner w/ PID?
08-31-2009, 12:32 PM
A lot of people make them: Snap-On Modis, Actron, Vertronix, and the Porsche specific Durametric can all do it
..check the model features, the better units usually have it.
