Old 08-17-2009, 06:58 PM   #1
Looks like AOS, but engine WOES
Long story short, I got a CEL, drove to Oreilly and pulled codes 1128 and 1130.
Restarted the car - cloud of smoke. Thought it was an AOS, but after a minute of idling - engine started to WOE. I turned it off and towed the car home.
Restarted it w cover off - no woeing at first, just sucking noise and rough idle started to woe after about a minute again.
Oil level is fine, no metal in the oil or on the drain plug. coolant is clean.
Any input is apreciated.
al83s is offline   Reply With Quote
Old 08-17-2009, 07:08 PM   #2
Engine Surgeon
remove the oil cap while the engine is running and see if the sucking sound goes away..
Old 08-17-2009, 09:58 PM   #3
Maybe it's too late and I'm just not putting it together... WOE?
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 08-17-2009, 10:27 PM   #4
Sorry. English is my second language.
Engine makes noise that sounds similar to wheel bearings going out but more constant. Humming I guess. I will see if I can post a vid tomorrow. No rattling though so I hope its not IMS. Fingers crossed.
Old 08-18-2009, 10:10 AM   #5
Engine Surgeon
This may be the IMS bearing!! Is it high or low pitched?
Old 08-18-2009, 10:50 AM   #6
I know it could be very dangerous to run an engine with (potentially) the IMS getting ready to fail, but if we could all hear what it sounds like.... it would help us in the event that we are facing the same set of circumstances. Be careful!!!!
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 08-18-2009, 01:09 PM   #7
Taking the oil cap off w engine runing was a PITA, deffinately alot of vaccum there but hissing went away.
Low pitched humming noise was not there today, just a puff of smoke, hissing and ocasional backfiring.
I went ahead and ordered new AOS, Id rather spend 90 bucks before I pull the motor out.
Thanks for the input guys. I will post an update when AOS arrives.
Alex
Old 08-18-2009, 01:24 PM   #8
Engine Surgeon
The AOS has two different modes of failure.. Based on the fact that you had vacuum on the oil cap and the hissing went away when the cap was removed, I'd say the AOS has failed in mode #2.
When this happens the engine can be compromised as the extreme crankcase vacuum pulls oil from the oil pick up tube, reducing oil pressure at idle and low speeds..
I just had this happen to me on a test drive a few weeks ago, the event almost cost me my life when the AOS failed and oil vapors lit up behind the car like Haley's Comet...
When the AOS fails with method 2 you need to ensure the front and rear engine seals have not been sucked into their bores by the vacuum too deeply and that the oil fill tube wasn't broken when the vacuum sucked it flat..
Did your oil pressure light illuminate?
Old 08-18-2009, 06:13 PM   #9
is there a room for improvement here. an anti vacuum value on the main crank case such that the seals does not get sucked in??
sb01box is offline   Reply With Quote
Old 08-18-2009, 08:07 PM   #10
Question
Mine is doing the exact same thing... It does smoke every start up... What do you mean by the two methods of failure? I have been fighting a non Porsche dealership on this, I am now going to take it to the real guys.
BoxsterS21 is offline   Reply With Quote
Old 08-18-2009, 09:54 PM   #11
Engine Surgeon
AOS MOF#1= Clouds of white smoke, CEL, the engine runs like crap.
AOS MOF#2= No smoke, no CEL. High pitched squeal at idle, collapsed oil fill tube, FMS and RMS pulled into their bores due to high crankcase vacuum, oil pressure indicator may illuminate if oil is at temperature, at idle.
Its all according to what part of the diaphragm fails.... Thats what dictates the symptoms.
and a Dealership may not be the best place to go, some of them have never seen a MOF2 from an AOS and they may tell you that you need a new engine.
I received a perfectly good core this way.. I threw a used AOS on the engine and it still runs today without issues... I bought the engine as a "blown Core" for 300 bucks.
Old 08-19-2009, 04:51 PM   #12
Talking
Mine is doing Failure number one... Thank you sooooo Much! :dance:
Old 08-19-2009, 08:55 PM   #13
This post was in good time!! I stopped today at the bank and heard a squealing (motor never makes noise) and when I realized it was my car I popped the oil filler cap and there was a ton of vacuum and the noise went away when removed.
I stopped the car immediately. I will grab a new AOS at the local dealership ($163!!!) but its in stock. I hope I caught it quick enough before damage was done.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
944boy is offline   Reply With Quote
