Old 08-10-2009, 06:36 PM   #1
Johnny Danger's Avatar
Under Pulley
Does anyone have any experience using a light weight under pulley on a 986 boxster s
(e.g. Mantis Racing, BBI Tuning) ?
Old 08-10-2009, 06:47 PM   #2
Engine Surgeon
Yes I have data from 3 different units compared to stock on 4 different engines.
The one I tested on ly 911 saturday was good for a 10HP gain at the rear wheels, on my dyno.
Old 08-10-2009, 06:56 PM   #3
Who's product did you use ? And what did the install entail ? Some "tuners" in my neck of the woods have suggested that it's a more involved install than one would think.
Johnny
Old 08-10-2009, 07:45 PM   #4
Engine Surgeon
The unit I installed this weekend was one of our products that I am gathering data from this weekend at an event.. It has not yet been released, ad it is the smallest on the market. I want to determine what temperatures I see with the coolant and power steering fluid and go from there.
The install isn't that hard.. The biggest pain is having to trim down the boss on the block that holds the engine lock, but I made a piloted end mill for this that works great in a drill and makes a 2 minute job out of it..
The other pain is holding the crank while torquing the crank pulley bolt to the specified value.
I can swap one in about 40 minutes start to finish, on a test car in about 25 minutes with the engine hot on the dyno.
"Tuners" generally aren't very good wrenches...
Old 08-10-2009, 08:37 PM   #5
would a pulley make a noticeable power gain on a 2000 2.7?
_____________________________
Cars:
2007 MDX - Wife's mommy mobile
2006 RL - My daily driver
2000 Boxster - Ocean Blue Base 5spd on Black Full leather. 18" wheels and M030.
Boxster mods I've added: Rear speaker kit, Painted Calipers, Painted Bumperettes, Painted Center Console, 987 Shifter Assembly, 3 Spoke Steering Wheel, Clear side markers, 03+ rear lights, de-snorkeled.
23109VC is offline   Reply With Quote
Old 08-11-2009, 06:07 AM   #6
Engine Surgeon
More than about any other bolt on that we have done so far... Certainly more than a 2K exhaust system.
Old 08-11-2009, 02:16 PM   #7
If things go well this weekend, when do you think your pulley will become available ?
Old 08-11-2009, 05:22 PM   #8
Engine Surgeon
It'll take more time than that.. I want to do some studies in low speed applications with my Wife driving the car daily and monitor battery voltage and coolant temps Vs the stock arrangement.
Old 09-24-2009, 07:54 PM   #9
jaykay's Avatar
I am running a Mantis pulley......at the moment
Old 09-27-2009, 09:23 AM   #10
Engine Surgeon
Our 4" version is now fully tested on the street.. After a DE, 4,500 street miles (and a lot at low speeds and in traffic with the A/C and head lights on) and coming within 1/2 of 1 MPH from a Land Speed Record the unit has proven it's self.
I've seen a minimum of 5HP gain (at the rear wheels) with this unit along with LOWER coolant and power steering fluid temps. One engine has seen 8 HP, but it was one of my high revving 3.2>>3.6 modified engines.
