Old 06-20-2009, 06:27 PM   #1
Multiple CEL Codes
Greetings all! I am a very happy owner of a recently acquired 97 Boxster with 95k miles on it. The cars runs great but is producing many CEL codes:
P0134 Oxygen Sensor Ahead of Catalytic Converter (Cyl. 1 - 3) - Interruption of Signal
P1123 Oxygen Sensing Adaptation Area 1 (Cyl. 1 - 3) - Lean Threshold
P1125 Oxygen Sensing Adaptation Area 1 (Cyl. 4 - 6) - Lean Threshold
P0410 Secondary Air Injection System - Signal Implausible (Cyl. 1 - 3)
P1115 Oxygen Sensor Heating 1 After Catalytic Converter - Above Upper Limit
I don't know the maintenance history, so after reading through many posts here I am leaning towards having all four 02 sensors replaced. The P0410 code makes me think there is another issue... I think I will try cleaning the MAF sensor and if it returns, have that replaced, too. Thoughts?
-Zack
zblack is offline   Reply With Quote
Old 06-20-2009, 10:14 PM   #2
Topless's Avatar
Looks like wiring issues. Rodent damage or heat damage between your sensors and DME. Give it a look.
Old 06-22-2009, 09:54 AM   #3
OK. I'm going to pop the trunk cover and check the wiring today. Someone else suggested resetting the DME/ECU by disconnecting the battery for 15 mins? About the O2 sensors... If I decide to pull the trigger and replace all four, are they all the same? I've seen them as low as about $80 on eBay but the info seems inconsistent on wether the ahead/behind catalytic converter are the same sensors. Thanx!
Old 06-22-2009, 02:32 PM   #4
Topless's Avatar
Lots of info on O2 sensors here if you do a search but... none of your error codes point to failed sensors. Throwing parts at the problem can be agonizing and expensive.
Old 06-22-2009, 07:19 PM   #5
Understandable. Having read so many raves on here about how much better everyone's cars performed after having the sensors replaced, I figured it would be a good idea regardless. My boxster has had 4 previous owners and 95k miles put on it, and I don't know the maintenance history. I found a good deal on a set of four new Bosch sensors for only $299 so I decided to grab them. Also, I pulled the trunk cover to inspect the ECU and cabling and it's all in perfect condition - doesn't look a day old.
