timing/retrofit ims
i made the mistake of removing the ims bearing without doing research.i plan on puting a lnengeniering retro fit but now the shaft is not centered and i don t realy know what to do to surely replace the bearing .can somebody please explain the procedure . thanks john
Pull all the tensioners and index them for reinstallation..
Once the tensioners are pulled the shaft will easily recenter in the bore... We are doing an install DVD on this, but do not have it completed yet. |
Great, thanks for the input. Should I be worried about the cams being off timing now? I haven't rotated the motor.
Thanks again, John |
You should have pulled the tensioners first... BUT if the engine hasn't rotated the timing could not have moved...
| All times are GMT -8. The time now is 02:25 AM. |
