Old 01-12-2009, 05:46 AM   #1
Engine Surgeon
Exclamation All "IMS failures" are not IMS failures! Carnage within!
Victim: 2001 M96 engine pulled from a Boxster S. Mileage reported to be 45K
Catastrophic Failure
MOF #14
We have discovered another MOF (Mode Of Failure) related to the M96 engine. This one is our most recent tear down that occurred with a 45K mile engine. It is one of the most radical failures that could occur with an engine and we have gained a good understanding of why it occurred. More importantly we are in work already on another "overkill" part to solve this issue that we can apply during our engine updates for our complete engines and component kits.
This is interesting, because this engine fooled us, it also fooled a Porsche Dealership and another independent Porsche shop that had diagnosed the engine prior to it being sent into us. The engine had all the classic symptoms of a seriously failed IMS that had resulted in valve timing alterations, thus colliding the majority of the valves with the pistons, a true nasty affair. When the intake manifold was pulled we immediately saw carnage (broken valves and chunks of piston in the intake ports!) and since I love to dissect engine failures I stayed late to see what was inside this beast.
As the engine was torn down I was expecting to see the IMS shredded, but every time we turned the engine while removing the valve train the only symptom that the engine had was altered valve timing, this was odd. Typically when an IMS fails this badly the shaft shears in half and "parks" the valve train that operates from the opposite end of the IMS drive, located at the flywheel end of the engine (I am trying to explain this so you guys can understand!) and that results in all the things we had witnessed. When this happens the IMS will not turn, so the oil pump stops functioning and 3 cylinders worth of valves stop actuating, resulting in a big mess.
This is where it gets interesting:
When the IMS fails to the point of allowing piston collisions with the valves the IMS is most always sheared.. But when this engine was rotated fore and aft the IMS was responsive to the change in crank position and the typical damage to the oil pump that results from IMS failure was not present.
How could an engine have such a radical failure, with all the same initial symptoms as the IMS failure and have an IMS that was responsive to crank position changes, intact and still functional??? Read on...
When the first cylinder head was removed the engine still had all the symptoms of an IMS failure, but when the second head was removed that cylinder head was found to be perfectly intact with zero piston/valve interference and no damage. The engine was still spotlessly clean inside and showed no signs of abnormal wear on the "intact" bank of cylinders.
As we went deeper it got interesting as it seemed the valve timing was radically off on both sides of the engine, but all the timing chains were intact, nothing was broken and all was in decent condition. At this point of the autopsy we knew that when the case was split we'd find something we hadn't seen before.
When the case was split the IMS came out in good condition without any oil inside it and without any signs of bearing failure or wear. We immediately removed the crank carrier and then we saw the culprit..... The crank/ IMS drive chain tensioner pad was non existant and the tensioner was broken in half! We then dug through the rubble and found the broken pieces and started putting the pieces together to figure out what happened.
Why the valve timing changed:
Because the main drive chain for the IMS lost all tension when the "tensioner" sheared in half, thus allowing the IMS to stop rotating and "parking" the valves. When this occurred a couple of cylinders had open and partially open valves that then collided with their pistons and that resulted in scattered parts, a loud bang and chunks of piston being emitted from the tail pipe...
What we learned:
Something we had never really paid close attention to was the shape and thickness of this tensioner through the various years and models of the M96 engine. We pulled this piece from several engines and started comparing them in shape, interchange, composition and design. We immediately noted that the the early 2.5 tensioner was thicker across the area where this tensioner had broken and that the early unit also had a hardened steel contact surface for the chain adjuster to ride against. The later 3.2 unit had been made thinner through the area where the breakage occurred and had a PLASTIC surface for the chain adjuster to contact.
The part number from the two parts were the same, but one was a .4 while the other had a .5 suffix.
So, why was this part changed? Why would anyone ever replace a hardened steel wear surface with something comprised of plastic, when even the steel wear surface does typically wear....
This is a MOF that we have never seen before and never heard of occurring. After seeing this failure and it's symptoms I believe that some of the "IMS failures" that are diagnosed without an engine tear down are actually this MOF, or at least something similar to it, that cannot be thoroughly understood without complete dissection of the engine.
That said, we are already in work creating a two new components that will solve this MOF issue. First we are making a billet aluminum tensioner unit made to use the OE tensioner pad, this will replace the lightweight, cast aluminum factory unit. This will incorporate a larger, tool steel wear surface much like the earlier 2.5 unit pictured below. Making the wear surface larger will increase the contact patch that the chain adjuster sees, thus increasing service life.
Secondly we are making the wear surface "button" compliant with the OE tensioner, so those that have the early tensioner can replace their wear surface with a larger, stronger part if they don't choose to utilize the entire billet tensioner that we are creating.
I'll never trust one of these OE tensioners again, we'll be applying the billet units to ALL our engines effective immediately and all builds are currently halted while this component is being made.
The key to avoiding problems like these are to make the parts heavier duty than they "need" to be on paper... I call it "overkill Engineering" and it's what keeps things from failing... Its nothing more than classic hotrodding being applied to these newer, robotically assembled, mass produced engines.
We are now going through cores and doing research trying to specify when Porsche changed this tensioner.... I'll report back when we have concrete evidence.
Now for the pictures... More will be posted today on the "reliability" page at www.flat6innovations.com
The pictures speak for themselves, its mass carnage of an unreal kind.. The kind of stuff that makes it to our "trophy Shelf" filled with offerings to the Gods of Speed...
Old 01-12-2009, 05:54 AM   #2
Engine Surgeon
Exclamation
I had more pictures to post, but the software limited me to five..
Here are the pics of the two different tensioners. The broken unit came from the failed 3.2, the intact unit came from a 1998 2.5 Boxser engine.
Note the wear surface and the thickness of the tensioners.
Old 01-12-2009, 06:48 AM   #3
Brucelee's Avatar
WOW, Jake, great write up.
Any evidence in you opinion that this damage was abuse/neglect related or more of an assemtly flaw?
45K does not sound like a lot of miles for a quality engine.
Rich Belloff
Old 01-12-2009, 07:29 AM   #4
Engine Surgeon
The rest of the engine showed no signs of abuse or neglect... The engine failed at normal driving speeds, around 70 MPH.
Old 01-12-2009, 07:54 AM   #5
Jaxonalden's Avatar
It kind of hard to eye ball the thickness difference of the tensioners but I guess there is. I one thing I did see was the pot metal at the break. Those tensioners must be put under a tremendous amount of stress (I think of watching a motorcycle chain under power and then letting off) and to use crap metal is crazy.
So Jake, you think this could be the cause of some of the failures? Because of the carnage in a block after one lets loose that it simply is being overlooked and the blame is put on the IMS? If thats the case the fix seems so much easier to remedy.
Old 01-12-2009, 08:06 AM   #6
Yowzers! Great write-up Jake, even I could understand that. And the pictures, wow, what carnage. Pictures are not just worth thousands of words but dollars too!
kabel
kabel is offline   Reply With Quote
Old 01-12-2009, 08:27 AM   #7
Is this a part that an average joe with average joe tools can replace on his own?
Old 01-12-2009, 08:41 AM   #8
Jaxonalden's Avatar
No way, this involves engine removal and breakdown.
Old 01-12-2009, 08:47 AM   #9
Engine Surgeon
I tried to leave all the techno-babble out as much as possible and post at a comprehension level that those who haven't been inside this engine could understand.
Its a minute difference, but it does exist. Its so small that I had overlooked it until this instance.
The whole part is "pot metal" and crappy.
Unreal tension, especially when the vario cam comes in and everything in the top end of the engine tightens up.
Absolutely.It already has failed in this engine and I am sure it's not the first, but its the first time we have seen it.
The symptoms are exactly the same as an IMS failure, thats why it fooled everyone that had diagnosed it, even me.
Without TOTAL disassembly this would be misdiagnosed as an IMS failure. Since a majority of the engines are sent to Porsche for reman without ever being opened up, everyone **THINKS** that they had an IMS failure, when it really wasn't.
NO!!! It's not! To uncover this tensioner the ENTIE engine must be torn down, if you notice the tensioner attaches to the crank carrier, the first assembly installed into the engine when building it and the last assembly removed at tear down. There is no way to apply our updated part without removing every bolt from the engine, unfortunately.
We are doing a metallurgical survey on the broken part to see what it's comprised of, so we can look for the traces of this material when we pull oil samples from customer's engines orfor those who are part of our oil monitoring program. This will help diagnose issues before they occur.
With one of our engine assembly kits of updated components and our tools it could be done by following the DVD we are working on now... Otherwise this is a near impossible level of repair for a DIY project.
We klearn something new everyday...
Old 01-12-2009, 09:48 AM   #10
Porscheectomy
If I understand what I'm seeing correctly, it looks like a overloading failure, maybe due to a manufacturing defect or fatigue. Not a wear issue. I wonder if you'd ever get a warning from an oil analysis.
Old 01-12-2009, 10:22 AM   #11
Engine Surgeon
It does appear that the unit was overloaded, but all the up stream components that actuate it were in fine condition..
It appears that the tensioner wear pad may have worn and then been ripped off and that created the tensioner to operate at an odd angle that could have made it break..
An oil sample could seek out the wear materials from the tensioner pad in the oil and then if the chain is going metal on metal before a failure the elements of the tensioner would be in the oil as well..
Its a long shot, but we are already observing so many oil samples its just one more thing to add during analysis.
The newer tensioner being thinner with the plastic contact patch doesn't help anything.
Old 01-12-2009, 10:23 AM   #12
I wonder if that's a design flaw that would be easier to work up the old class action law suit on? Imagine a recall to replace those...
dmcutter is offline   Reply With Quote
Old 01-12-2009, 10:49 AM   #13
Quote: "If thats the case the fix seems so much easier to remedy.
NO!!! It's not! To uncover this tensioner the ENTIRE engine must be torn down, if you notice the tensioner attaches to the crank carrier, the first assembly installed into the engine when building it and the last assembly removed at tear down. There is no way to apply our updated part without removing every bolt from the engine, unfortunately."
Well, Jake, you don't have to answer my now apparently stoopid question over at RennTech!
Mike
PCA since 1970
70Sixter is offline   Reply With Quote
Old 01-12-2009, 11:30 AM   #14
edevlin's Avatar
Hey Jake, I know I am speaking for others on the fourm when I say I am sure glad you are in our corner with these engines. Keep up the good work!!!!
Ed
My Car Webpage
Old 01-12-2009, 11:50 AM   #15
Engine Surgeon
Ed
Thanks for the kind words.. I like to make things work and I prefer to work with things that are problematic, like this engine... We are full steam ahead making components to eliminate these issues.
As for a class action law suit, I am a hands on kind of guy and nothing thats settled in court is going to solve the issues this engine has.. I stay completely away from anyone who even mentions the word lawsuit...
If I can't fix it in my shop, I want nothing to do with it... The last time I checked a Gavel wasn't a tool developed for engine repairs :-)
Old 01-12-2009, 12:14 PM   #16
Dai
Jake, you are the Stephen Hawking (who could explain concept of black hole to common man) of M96. Thank you for your time effort in diagnose these engine. I have 2001 Boxster S and it is right at 43k miles mark. I am holding my breath now. :-)
Dai is offline   Reply With Quote
Old 01-12-2009, 12:33 PM   #17
Engine Surgeon
Don't be afraid.. Just drive it. If it breaks, then deal with it.
A lot of these engines fail, but a lot more don't...
Old 01-12-2009, 12:51 PM   #18
Thanks for the info. Too bad its not going be to an easy DYI preventative project for most guys, but its good to know that when and if it needs to be rebuilt, then it will be 'better than new'.
Until that time comes, as Jake said, just drive and enjoy the damn thing.
vijen6 is offline   Reply With Quote
Old 01-12-2009, 02:58 PM   #19
Dai
Not to worry Jake, your advice from Excellent magazine article helps. I do drive my Box year-round even at -35C here in Canadian winter. I guess if it breaks, I will be talking to you for a new engine. :-) Cheers and thanks again.
Old 01-12-2009, 04:26 PM   #20
Now that's the right attitude!
Jake maybe I missed it but was this off a trip or a manal trans?
kabel
