-   -   stiff clutch? (http://986forum.com/forums/performance-technical-chat/18212-stiff-clutch.html)
smiley4you 09-13-2008 03:18 PM
stiff clutch?
Any ideas how to make the clutch pedal easier, I read about changing the clutch booster spring, if it is a good idea how do I change it? Oh yeah my ride is a 99
Tool Pants 09-13-2008 06:42 PM
Is this the original clutch. How many miles on the present clutch.
smiley4you 09-14-2008 09:49 AM
40,000 miles and I think the original and it doesn't slip
spongebob 09-14-2008 09:53 AM
A stiff pedal can be a sign of a worn clutch my workshop told me.
I did the change my self and voila the pedal was a bit softer again. So this time they where right at least.
Tool Pants 09-14-2008 10:44 AM
A stiff pedal is a sign of a worn clutch. My 1997 with 67,000 miles on the original clutch almost took 2 feet to push the pedal down. Clutch was worn down to the rivets. With the new clutch I can press the pedal down with my thumb.
Some get more miles than I did. Some get less. Depends on how the car is driven.
I would say you are due for a clutch replacement. Bring it by a shop and have it checked out.
