Old 07-25-2008, 08:27 PM   #10
OK, I can't even begin to describe the level of frustration I have with this problem. Replaced the entire hub/ hub carrier/ wheel bearing assembly today and the problem has not changed.
So, to recap, we have replaced
1) Front control arms
2) Inner and outer tie rods
3) Springs, dampers, strut tops
4) Sway bars
5) Replaced tires on my wheels (BBS RSIIs, which are about as true as a wheel gets), balanced them 3 times. Problem existed on old tires and new.
6) Tried a set of factory wheels, same exact problem.
The only thing things that have not been replaced or swapped out now are the front thrust arms and the actual steering rack. What gives???????
Patrick
